I am new to op-amps and have a couple of questions.
I am building a function generator that operates in the range of 1-100000Hz.
The different waveforms have different voltage levels that I want to control. In a different thread I got some tip to change the voltage offset with a capacitor and resistors.
I also got a tip to use a op-amp. I have thought about the op-amp and it seems to be a good idea because of the buffer functionality.
Now to my questions
Can I use a differential amplifier subtractor circuit to change the voltage of a signal?
Eg. My signal is 2-7V. I connect the signal to Va(-) and 2V to Vb(+). Will the output signal become 0-5V? (with the right resistors)
Which op-amp should I buy for my project? (Signal generator or Synth)
It exists A LOT of different op-amps. I am not sure what to buy.
For example is LT104 (LT1014 Datasheet and Product Info | Analog Devices) a good one?
Any tip of another good op-amp that is cheap?
Yes. A difference amplifier with a gain of one will do that. If you want to go all the way down to 0V, it's best to use a bi-polar power supply (most op-amp circuits call for + & - power supplies anyway).
I'm not sure, but it's probably not too critical. Most op-amps can go to 100kHz.
Maybe I should buy both some single supply and some dual supply op-amps.
No they are both the same thing. You can use any op amp as a single rail or a dual rail it matters not as long as the total supply voltage is within limits.
