Hi!
i don't know wich op amp i can use (really i don't understand the op amps, and what they do XD)
the thing is... i'm trying to do a DAC to drive sounds from arduino to a speaker
the op amp used in the schematic is TS922, but i cant find that ones in my city (no, i cant buy it on internet for reasons)
my problem is... wich one i can use as substitute :s
i see that they (the store) have this (maybe they have others too)
TL081, TL082, TL084, LM741, LM3900, LM358, LM324, , LM311 , LM351 , LM339, OP07
I think TL084 and maybe OP07 are lower noise op amps. Not sure if they are single supply capable, or if dual supplys are needed.
Search www.ti.com for spec sheets, do some reading.
CrossRoads: tnx the thing is, that i see the datasheets of the most... but i don“t know what i looking for, i see a lot of values in which some looks more than TS922 than other (for example the TL082) but i really don't know if that values are the important ones for what i doing D: what i must look for?
OP07 and TL084 are not good replacement for it. If you look at the TS992 datasheet (did you ??) the most important stuff for you is following to see:
TS922 .. rail-to-rail dual BiCMOS operational amplifiers optimized and fully specified for 3 V and 5 V operation ... high output currents which allow low-load impedances to be driven. The devices are stable for capacitive loads up to 500 pF
So you have to look for similar devices. Google "rail-to-rail high output current single supply"
CrossRoad: ok! now i know what i can start looking for...
pito: yeah XD i see the data sheep, but i think i was looking for the table of values... i was comparing numbers to the opthers op amp, thnx with that i think i can find something more specific ... i hope to find something i can buy in my city... D:!
Need a low pass filter to take out the high frequency switching.
Can be simple R/C, or it could be an active filter, op-amp based, that would allow a sharper rolloff in frequency. http://sim.okawa-denshi.jp/en/Fkeisan.htm
