OpenMV - Failed to detect image sensor
I have connected to R1GIGA (with Shield and HM0360 VGA Monochrome camera) and followed the guide to setup OpenMV IDE on my mac. When I try to run the OpenMV display or HelloWorld example, I get an error “Failed to detect the image sensor or image sensor is detached”. The camera should be properly connected as I can run the Arduino specific examples to display camera feed on the shield. I can see Firmware is 4.5.5. Plus, I have also updated the setting to Grayscale and QVGA. See snippet from HelloWorld example. Any help is deeply appreciated.
import sensor
import time
sensor.reset() # Reset and initialize the sensor.
sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240)
sensor.skip_frames(time=2000) # Wait for settings take effect.
clock = time.clock() # Create a clock object to track the FPS.
while True:
clock.tick() # Update the FPS clock.
img = sensor.snapshot() # Take a picture and return the image.
print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected
# to the IDE. The FPS should increase once disconnected.
OpenMV team has created a bug to track this problem. Per their feedback only OV7675 is currently supported for OpenMV.
In order to make all relevant information available to any who are interested in this subject, I'll share a link to the bug report mentioned by @apant_2024:
The bug has since been fixed so the GIGA R1 WiFi HM0360 camera module should now be fully supported for use with OpenMV. Thanks for reporting this @apant_2024!
There is some related discussion on the OpenMV forum here:
