Opta error code:1
Hy to everyone, i just installed arduino PLC IDE and Arduino-PLC-IDE-Tools to program OPTA PLC.
I connect with USB-C to PLC and choose the com port, but when i try to download, i have always same error code:1.
I've try to reset with 2 taps but is the same thing.
I download the last version of both software and i use Windows 10.
Someone can help me?
Thank's to all
I have the same issue too, did you manage to solve this issue?
Same issue here. Continual Error Code 1, tried resetting 3 times.
Hello everyone!
The latest version of the PLC IDE (version 1.0.6) is available here: https://www.arduino.cc/en/software#arduino-plc-ide
More information about the setup process is shown in this tutorial: https://docs.arduino.cc/software/plc-ide/tutorials/plc-ide-setup-license/#1-arduino-plc-ide-setup
If you encounter the error message (error code: 1) while downloading the runtime, you can try again as follows:
  1. Put the board in bootloader mode by double pressing the reset button
  2. Select 'Automatic (BootLoader)' in the Opta configuration window > Other > Port, as shown in the attached screenshot.
  3. Click Download
