The Opta worked fine until I connected to the Cloud using this article.
https://docs.arduino.cc/software/plc-ide/tutorials/plc-ide-cloud-support/
Through the cloud, I connected the device to the Opta. No errors.
When connecting to the Opta PLC with the PLC IDE, I am getting the following errors.
I then put it in bootloader mode and tried to connect using PLC IDE.
The warning is an Invalid DFU suffix signature.
Then I noticed in the article that I needed PLC IDE 1.0.4 or greater. This is not available. I have requested the newest version of the software.
I then started the Arduino IDE to communicate to the Opta. The thinking is to put this in bootloader mode and download a sample program. Resetting the Opta. The program was loaded successfully but with the following errors.
Warning: Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release.
The sample program works with the Opta, but I am completely locked out from communicating to it using the Arduino PLC IDE.
Is there a way to completely clear the memory of the OPTA and not just put it in bootloader mode?
Thank you,
Garry
