Hello, I’ve made a 16x16 multiplex for my graduation cap (mostly) following the guide here.
Everything is working and I can make images for its intents and purposes but I was hoping for help with optimizing the code for longer messages. I’ll post the code below but it is mostly adapted from the code here.
Since this is a 16x16 matrix, each image that I program takes up ~300 bytes in dynamic memory from being stored in global variables. This means that I can only store about 7 images (though even that is pushing it). I want to learn or at least know if there are better ways of storing these arrays and calling them in the program.
I’ve already found options such as the one found in this thread but I’m not familiar with that method.
Thanks for any help!
* Show messages on an 16x16 led matrix,
* scrolling from right to left.
* Uses FrequencyTimer2 library to
* constantly run an interrupt routine
* at a specified frequency. This
* refreshes the display without the
* main loop having to do anything.
#include <FrequencyTimer2.h>
/*#define SPACE{
{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
{0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
#define SHIELD { { 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0, 1, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0, 1, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 0, 1, 1, 0}, {0, 1, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1, 1, 0, 1, 0}, {0, 1, 0, 1, 1, 1, 0, 0, 1, 1, 0, 1, 0, 1, 1, 0}, {0, 1, 0, 1, 0, 1, 0, 0, 1, 1, 0, 1, 1, 0, 1, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 1, 0, 1, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0}, {0, 1, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0}, {0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 0, 0}, {0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 1, 1, 1, 0, 0, 0}, {0, 0, 0, 0, 1, 0, 0, 0, 1, 0, 1, 1, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 1, 1, 0, 1, 1, 1, 0, 0, 0, 0, 0}, {0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0} }
byte col = 0;
byte leds[16][16];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[33]= {-1, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 14, 15, 16, 17, 18, 19, 20, 21, 22, 24, 26, 28, 30, 32, 34, 36, 38, 40, 42};
// col[xx] of leds = pin yy on led matrix
int cols[16] = {pins[1], pins[2], pins[3], pins[4], pins[5], pins[6], pins[7], pins[8], pins[9], pins[10], pins[11], pins[12], pins[13], pins[14], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix
int rows[16] = {pins[32], pins[31], pins[30], pins[29], pins[28], pins[27], pins[26], pins[25], pins[24], pins[23], pins[22], pins[21], pins[20], pins[19], pins[18], pins[17]};
const int numPatterns = 1;
byte patterns[numPatterns][16][16] = {
SHIELD
int pattern = 0;
// sets the pins as output
for (int i = 1; i <= 32; i++) {
pinMode(pins[i], OUTPUT);
// set up cols and rows
for (int i = 1; i <= 16; i++) {
digitalWrite(cols[i - 1], LOW);
digitalWrite(rows[i - 1], LOW);
clearLeds();
// Turn off toggling of pin 11
FrequencyTimer2::disable();
// Set refresh rate (interrupt timeout period)
FrequencyTimer2::setPeriod(2000);
// Set interrupt routine to be called
FrequencyTimer2::setOnOverflow(display);
setPattern(pattern);
pattern = ++pattern % numPatterns;
slidePattern(pattern, 300);
void clearLeds() {
// Clear display array
for (int i = 0; i < 16; i++) {
for (int j = 0; j < 16; j++) {
leds[i][j] = 0;
void setPattern(int pattern) {
leds[i][j] = patterns[pattern][i][j];
void slidePattern(int pattern, int del) {
for (int l = 0; l < 16; l++) {
leds[j][i] = leds[j][i+1];
leds[j][15] = patterns[pattern][j][0 + l];
delay(del);
// Interrupt routine
void display() {
digitalWrite(cols[col], LOW); // Turn whole previous column off
col++;
if (col == 16) {
col = 0;
for (int row = 0; row < 16; row++) {
if (leds[col][15 - row] == 1) {
digitalWrite(rows[row], LOW); // Turn on this led
else {
digitalWrite(rows[row], HIGH); // Turn off this led
digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
