I am seeing a general pattern. Transistors or MOSFETs design for larger currents >2 amps usually have heatsink pads. Optoisolators or SSRs even with 8+ amp ratings do not.
Why?
Do optoisolators produce less heat i.e. less resistance?
Aren't optoisolators essentially optocoupled photo "transistors"?
An 8-Amp SSR is usually larger than a MOSFET with more surface area to dissipate heat so they may essentially have a heatsink built-in. And some higher power SSRs are designed to be mounted on some kind of metal plate that can act as a heatsink.
A DC SSR is usually built-around a MOSFET (and an opto-isolator) and AC SSRs normally use TRIACs which also dissipate a bit of heat-power.
...I made some homemade SSRs with TRIACs. The TRIACs are mounted to the inside of a metal electrical box which doubles as a heatsink.
