set higher baud rate in sketch and in firmware. set 250000 baud
in WifiLink config.h
I changed to
#elif defined(GENERIC_ESP8266)
#define BOARDMODEL "GENERIC_ESP8266"
#define ARDUINO_BOARD "esp8266" //mdns
#define ESP_CH_UART
#define BAUDRATE_COMMUNICATION 250000 // to start with SoftwareSerial, set 115200 for good connection
#define WIFI_LED 14
#define SSIDNAME "TVH-SPA"
#endif
and in MEGA sketch
I changed to
#if !defined(ESP_CH_SPI)
Serial3.begin(250000); // speed must match with BAUDRATE_COMMUNICATION setting in firmware config.h
WiFi.init(&Serial3);
#endif
when trying speed 250000 it wrote on serial "Communication with WiFi module not established"
when I lowered to 115200 (both in MEGA and in WifiLink, config.h)
it got back online
but same output - it stops on Flashing sketch
Connecting to board ... done
Uploading sketch ... done
Flashing sketch ... Error flashing the sketch
I have another Board of same type at the post office, waiting to be picked up.
I can get it within the next days and try a fresh start if you think that could make a difference
Out of curiosity
Have you by any chance worked with a Board like this before?
Or are you helping blindfolded?
TroelsDK:
@JurajI have another Board of same type at the post office, waiting to be picked up.
Out of curiosity
I have a Mega and I have an esp8266 module. I tested WiFiLink with ArduinoOTA on Mega with esp8266 on Serial3.
Right now I have it here, but with AT firmware in esp8266. I develop a new WiFiEsp library. It runs at 500000 baud.
Any progress on this. I am stuck with similar problems on Mega +WiFi R3 ATmega2560+ESP8266 (32Mb memory).
So when I upload this code using Arduino Mega 2560 (Optiboot):
#include <WiFiEspAT.h>
#include <ArduinoOTA.h>
#if !defined(ESP_CH_SPI) && !defined(HAVE_HWSERIAL3)
#endif
while (!Serial);
Serial.println("Program 2");
// initialize Serial1 for communication with the WiFi module
Serial3.begin(115200); // speed must match with BAUDRATE_COMMUNICATION setting in firmware config.h
#endif
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
// waiting for connection to Wifi network with settings in the WiFi module
Serial.println("Waiting for connection to WiFi");
Serial.print('.');
Serial.println("Connected to WiFi network.");
// start the WiFi OTA library with internal (flash) based storage
ArduinoOTA.begin(WiFi.localIP(), "arduino", "password", InternalStorage);
// you're connected now, so print out the status:
printWifiStatus();
// check for WiFi OTA updates
ArduinoOTA.poll();
// add your normal loop code below ...
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
It gives me this:
Using library WiFiEspAT at version 1.1.0 in folder: C:\Users\Sanket\Documents\Arduino\libraries\WiFiEspAT
Using library ArduinoOTA-master at version 1.0.3 in folder: C:\Users\Sanket\Documents\Arduino\libraries\ArduinoOTA-master
"C:\\Users\\Sanket\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-size" -A "C:\\Users\\Sanket\\AppData\\Local\\Temp\\arduino_build_9743/SerialWiFiOTA.ino.elf"
Sketch uses 16276 bytes (6%) of program storage space. Maximum is 261120 bytes.
Global variables use 1135 bytes (13%) of dynamic memory, leaving 7057 bytes for local variables. Maximum is 8192 bytes.
C:\Users\Sanket\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Sanket\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega2560 -carduino -PCOM8 -b115200 -D -Uflash:w:C:\Users\Sanket\AppData\Local\Temp\arduino_build_9743/SerialWiFiOTA.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Sanket\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x67
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0d
avrdude done. Thank you.
An error occurred while uploading the sketch
But I can upload the code with "Arduino Mega or Mega 2560" board. Please Help!
what progress? everything works.
you didn't burn the Optiboot bootloader, if you can upload as normal Mega
Hey Juraj.. Thanks for your reply..
Can you please guide me how to burn the Optiboot bootloader. I am new to this.
Thanks!
sanketpatel87:
Hey Juraj.. Thanks for your reply..Can you please guide me how to burn the Optiboot bootloader. I am new to this.
Thanks!
setup the programmer hardware and selection in Tools menu as for any ATmega bootloader flashing.
if you don't have an AVR programmer, you can use a second Arduino https://www.arduino.cc/en/Tutorial/ArduinoISP
then, if you copied my_boards, which includes the modified Optiboot for ArduinoOTA, select the "Mega 2560 (Optiboot)" and use Burn bootloader command in Tools menu.
So I have burned the bootloader with another Arduino and upload to the device with the Arduino Mega 2560 (Optiboot) and COM port is successfully uploaded.
Now I want to upload it with network port which gives me following error
C:\Users\Sanket\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0/bin/arduinoOTA -address 192.168.1.104 -port 65280 -username arduino -password password -sketch C:\Users\Sanket\AppData\Local\Temp\arduino_build_343131/SerialWiFiOTA.ino.bin -upload /sketch -b
Connecting to board ... failed!
If I change the port from 65280 to port 80 in platform.local.txt it connects and uploads to the board but gives me this error
C:\Users\Sanket\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0/bin/arduinoOTA -address 192.168.1.104 -port 80 -username arduino -password password -sketch C:\Users\Sanket\AppData\Local\Temp\arduino_build_749734/SerialWiFiOTA.ino.bin -upload /sketch -b
Flashing sketch ... done
Error flashing the sketch:FileNotFound
Please help!
don't change the port.
what firmware is in esp8266?
what networking library do you use for ArduinoOTA library example in Mega?
did you read this?
Juraj:
Ok. Noted.what firmware is in esp8266?
I have flashed with WifiLink firmware.what networking library do you use for ArduinoOTA library example in Mega?
I have tried with both WiFiEspAT and WifiLink librariesdid you read this?
ArduinoOTA/README.md at master · JAndrassy/ArduinoOTA · GitHub
Yes I have gone through this but it seems something is missing which i cannot figure out.
So I have an update. I first uploaded this code with Arduino Mega 2560 (Optiboot)
#include <WiFiLink.h>
#endif
char ssid[] = "LCC"; // your network SSID (name)
char pass[] = "Laxmiconstco@44"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
//Initialize serial and wait for port to open:
Serial.println("Hello 1");
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
#endif
if (WiFi.checkFirmwareVersion("1.1.0")) {
WiFi.resetESP(); // to clear 'sockets' after sketch upload
delay(500); // let firmware initialize
//Check if communication with the wifi module has been established
if (WiFi.status() == WL_NO_WIFI_MODULE_COMM) {
Serial.println("Communication with WiFi module not established.");
while (true);// don't continue:
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
ArduinoOTA.begin(WiFi.localIP(), "Arduino", "password", InternalStorage);
ArduinoOTA.poll();
Then I upload the same code with different debug Serial.println("Hello 2");
It uploads successfully
C:\Users\Sanket\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0/bin/arduinoOTA -address 192.168.1.104 -port 65280 -username arduino -password password -sketch C:\Users\Sanket\AppData\Local\Temp\arduino_build_802417/ArduinoOTAMegaWifiShield.ino.bin -upload /sketch -b
Sketch uploaded successfully
But shows the same message "Hello 1" when connected back to COM port and viewed in Serial Monitor. It is not running the new Sketch.
Finally got it working! Thanks for your help.
I was using a different bootloader.
sanketpatel87:
Finally got it working! Thanks for your help.I was using a different bootloader.
so it was not easy, but doable
Hey Juraj!
I have another problem to submit to you!
I want to update OTA both sketches on my ATmega2560+ESP8266 via urls.
I got the ESP side implemented with <ESP8266httpUpdate.h>
For the MEGA side, here is the scheme I followed:
Upload the Mega 2560 (optiboot) bootloader on the ATmega2560 (I confirmed that it was installed, as I can now only upload using this board configuration from Arduino IDE).
Compiled the sketch binary using Mega 2560 (optiboot) board profile.
Download the binary update from URL onto the SPIFFS of ESP.
Transfer data from ESP to MEGA using the serial connection.
Use the functions InternalStorage.open(), InternalStorage.write(), InternalStorage.close(), InternalStorage.apply() to write and apply the binary update.
Now, my problem is that the Mega does not apply the update correctly. I tried both HEX and BIN files, and got the following behavior: the RED LED above GREEN flashes continuously (error?), and the arduino has lost the initial sketch.
The Arduino does not work until I re-upload the sketch from Arduino IDE. I wonder if there is something wrong with the binary files I am uploading. There are 4 files in the build folder, 2 HEX (with/without bootloader) and 2 BIN (with/without bootloader).
Thanks in advance for the feedback!
Tony
In case you have time to take a look, the code is here:
In summary, the HTTP fetching to SPIFFS and transfer via serial is done by:
File httpFile;
void httpGet() {
// Check if http file handle still open?
if (httpFile) httpFile.close();
// Stream file to flash file system
unsigned long httpSize;
megaLen = readBuffer(megaBuffer);
httpFile = SPIFFS.open("/http.tmp", "w");
if (httpFile) {
if (httpClient.begin(megaBuffer)) {
if (httpClient.GET() == HTTP_CODE_OK) {
httpClient.writeToStream(&httpFile);
reply(HUB_ESP_ERROR, "HTTP: url not found!");
return;
httpClient.end();
reply(HUB_ESP_ERROR, "HTTP: cannot connect!");
return;
httpFile.close();
reply(HUB_ESP_ERROR, "HTTP: flash drive error!");
return;
// Prepare file for reading
httpFile = SPIFFS.open("/http.tmp", "r");
httpSize = httpFile.size();
// Send back file size
writeCMD(HUB_HTTP_GET);
Serial.write(4);
writeLong(httpSize);
void httpRead() {
// Stream required number of bytes
megaLen = 0;
if (httpFile) {
// Read requested bytes, as long as there are any
unsigned char requestLen = readChar();
while (httpFile.available() && megaLen < requestLen) {
megaBuffer[megaLen++] = httpFile.read();
// Send it to mega
writeCMD(HUB_HTTP_READ);
writeBuffer(megaBuffer, megaLen);
The update on MEGA is carried out with:
void readHttp() {
// Store data to Packet/OTA update
if (readBuffer()) {
for (unsigned char i=0; i<espLen; i++)
InternalStorage.write(espBuffer[i]);
void checkUpdate() {
// Fetch update file on ESP
Serial.println("Downloading MEGA update...");
writeBuffer(urlMega, strlen(urlMega));
while (lastCMD != HUB_HTTP_GET)
if (Serial3.find("CMD")) processCMD();
// Check update size
if (!httpSize) {
Serial.print("Error: update not found.");
return;
// Check there is enough storage for update
if (!InternalStorage.open(httpSize)) {
Serial.print("Error: not enough space to store the update.");
return;
// Transfer update file to MEGA
unsigned long recvSize = 0;
while (1) {
// Request next http packet
writeChar(200);
delay(10);
// Wait to receive packet
while (1) {
processCMD();
if (lastCMD == HUB_HTTP_READ)
// Check if packet was empty
if (espLen)
recvSize += espLen;
// Close the internal storage
InternalStorage.close();
Serial.print("Received: ");
Serial.print(recvSize);
Serial.print("/");
Serial.print(httpSize);
Serial.println(" bytes");
// Apply update
Serial.println("Updating MEGA firmware...");
Serial.flush();
InternalStorage.apply();
P.S: The function processCMD invokes readHttp()
One more thing: printing to Serial the HEX values sent to InternalStorage(), they match what I read on my PC when reading the BIN file with an HEX editor...
InternalStorage expects bin file.
Juraj:
With or without bootloader?
(I suspect without).
I will try tomorrow to load the bin file from a SD card, so i can figure out if InternalStorage actuallt works correctly on my board.
8bit-Dude:
(I suspect without).I will try tomorrow to load the bin file from a SD card, so i can figure out if InternalStorage actuallt works correctly on my board.
without bootloader. it is written from address 0 as continues data.
a valid bin with bootloader for Mega would have to be 256kB large. (suspicious 65536 bytes has the bin created by the builder)
