I have an Outdoor P10 panel - 16 x 32 RGB.
Identified on back as "p10-4s-3535-3216-ja1".
The connector if labeled as a HUB75D.
The board contains 4 FET packets, 2 - 74hc245 drivers and 24 - TC5020 (16 led drivers).
The HUB75 connector has address lines A, B, C, D. On many panels, these lines go to a multiplexer - but these do not.
A, B, C, D are active LO - and when 64 bits of data is shifted in on one of the color lines - two rows of leds are lit.
The bottom half of the panel can be addressed by address lines A, B, C, D and 64 bits of data.
More than 64 bits no not light up leds on the top half.
I am not using a library - currently bit banging to figure out how the panel works. All of the existing libraries have address lines (A, B, C, D) feeding a multiplexer - and this board does not have one.
I can NOT figure out how to address the top half (or bottom if my orientation is upside down). I thought they may have used an "E" address line labeled as GND - but that was not the case.
Any ideas as to how to address the other half of the panel?
Thanks
