Hi everyone,
I managed to use an attiny84 5V output voltage to send it to a Bluetooth input pin which is 3.3V and that's why I used a voltage divider . 10 and 15k allows almost a half milli amp to go through, but, the problem is, the output voltage is almost zero ( about 23mV).
Can anyone please tell me what I missed?
No, if you have trouble, trying to desoldering it is one of the first steps.
This is because it is possible that the soldering is defective or the component is defective.
(The one component can't be true measured unless it is removed.)
Especially, If think it's not a code issue at only your think.
If not that, show all the code here...
I assume it measures OK before connecting to the Bluetooth board? A voltage divider will always work by itself if the voltage-input is correct and if the resistor values are correct. It's based on physics and laws of nature...
If so, the input on the Bluetooth board has too-low of an impedance and it's "loading" the voltage divider. (A lower resistance in parallel with R2 will lower the voltage.)
That could happen if it's not really an "input" pin, or maybe if the Bluetooth module isn't powered-up.
That is an input-pin, right? Not the 3.3V power input?
It's rather complicated
circuit.
R317 is 15K and which is connected to GND
R318 is 10K and which is connected to PA1
I checked the continue between the tiny84 output pin, the two resistors to the bluetooth module input pin. Everything is ok and it's not shorted to ground or something like that.
It's not easy, but, I'll try desolder the components one by one to discover the wrong part.
Everything is soldered to the board. Please see the pic above.
agree with u
It's input pin not powering pin with 3.3V tolerance.
It's the pin PIO4 on HM-10 Bluetooth module actually. By selecting the right mode, it turns this pin as an INPUT mode. I tested my circuit on that BL module before I soldered it, but I used an STM32 3.3V output pin to test the circuit instead of ATtiny84 with voltage divider.
