Outputting value from analytic scale
Hello everybody!
I have old analytic scale (Sauter ar 1014) and I have hard time figuring out correct pinout for RS232. It doesn't have any manual with it and can't find one from internet.
So my questions are:
Is Din5 connector to dsub9 connector always the same?
Should I first connect it with pc, and try to figure out baudrate etc, or directly to arduino with max3232 chip?
What are those orange green black connectors?
Any directions where to start would be welcome!
There is a standard for that, try this link: https://www.scalemanufacturers.org/PDF/ScaleCommProtocol5199M1.pdf see if that helps.
Hi! That is so helpful!
It seems that the orange green and black are ttl connectors!
5 volts seems to imply that. Need to check tomorrow more. Should both tx and rx be 5v?
I don't think so. The DIN connector isn't standard for RS-232.
Even the DB9 wiring isn't completely standardized. There is DTE and DCE where the RX, TX, and handshaking are switched-around. I don't know which way a standard computer port is wired but if you want to connect two computers together you can't have TX to TX so there are null-modem cables or null-modem adapters to crisscross the connections.
And the handshaking is not always used.
"Real" RS-232 uses positive & negative voltages. There are converter chips like the MAX232 but if your scale/balance is 5V and you are interfacing with a 5V Arduino, that's not necessary... You'd need converters on both ends and that would be silly...
If it is RS232 and meets the standard Tx will be a -3 to a -25 volts. Rx is positive and generally around 3-9 volts. These are just rules of thumb, no warranty of accuracy.
Seems that the three pins (orange, green, black) are ttl serial connection.
Why it's reading 3 volts (fluctuating between 3.3 and 3.7) from green to orange? From black to orange its 0 volt. And from black to green 5 volts.
Chatgpt suggest that its 3.3v ttl logic?
My guess is
black - ground
green - tx (active high)
orange - rcv (no signal input)
Okay, Those three pins ( black green orange) are for some sort of trigger ( black and green) orange is maybe for grounding?
I moved to Din 5 connector and it shows me that ground is on the middle and all 4 others show 5 volts. Seems to indicate 5v ttl logic?
Okay,
I can't seem to get any input from scale. Is the scale broken as all the pins (except ground) are constantly 5 volts?
my code:
 LiquidCrystal_I2C lcd(0x27, 16, 2); // Creates I2C LCD Object With (Address=0x27, Cols=16, Rows=2)
int incomingByte = 0; // for incoming serial data
      Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
      lcd.init();
  lcd.backlight();
  lcd.setCursor(0, 0);
      // send data only when you receive data:
      if (Serial.available() > 0) {
        // read the incoming byte:
        incomingByte = Serial.read();
        // say what you got:
        lcd.print(incomingByte);
Okey, some updates!
Din 5p connector have ground in the middle and the others are 5 volts.
Trying to connect the pins for ground have different effects on scale.
Yellow pin grounded make circle appear below minus/plus operator (its toggle, so every time pin is grounded the circle either appears or disappears)
Red pin grounded make scale change units. As long as the pin is grounded, the unit is different.
Other two pins, green and orange make scale just reset.
Any ideas how to get data out from this?
You have not shown us that there is any data to get out!
Yeah,
I do not know how to get data to show up on serial monitor or in the lcd.
Next step is making din5 to dsub9 cable and trying with pc. Then logic analyzer. But I don't know if there is any analyzing if all pins are constantly 5 volts.
Perhaps heading off on a tangent here, but it looks like your scales are fairly old, so out of any warranty etc. Without access to the exact user manual for the scales, it may save a lot of effort and guessing if you were to remove the cover and examine the internals to determine if the device has any serial output capability. Look for an RS232 (most likely) line driver chip and then where it connects to externally.
EDIT: I see that there may be mains voltages present inside so make sure that the scales are unplugged first before removing any covers.
Perhaps the data connection is under the metal cover under the three banana jacks. Did you ever look?
Some other on-line pics show another connector there:
That connector could be for buttons on a remote control pendant that lets you operate the scale without touching the unit.
One is probably TARE and the other ZERO.
There is two empty headers. One named st3 with 4 pins and st6 with two pins.
Yeah,
It was empty. I think you are correct there should be din socket here for rs 232 connection
Thank you @DaveX for this picture. Din connector looks exactly the same as with other scales which uses din connector for rs232!
