Hi Peeps ! I'm using OV2640 to take photos but is there any possible way to do so thru coding only and not via accessing the host app to take photo? Much help appreciated
We need much more information about your setup and your problem.
Ok so I'm actually able to snap a photo using a push button with following codes (P.s i just added a few of my own codes from and example for it to work)
However, I have yet to be able to save the image into a jpg file...
Any ideas?
Push_Button___CAM.ino (31.5 KB)
No links to the used hardware, no wiring diagram, no description of how the host (I assume that's a PC) is intended to interact with the Arduino. We need much more information!
The code is horribly formatted. The "Auto Format" function in the "Tools" menu of the IDE does a simple formatting if you aren't able to do it yourself.
