Overcoming Backlash in Gearboxes
My project involves 4 DC motors with worm gear gearboxes which of course have backlash. The motors are used to articulate the joints of a robotic arm and are fitted with encoders to control their position (e.g I say move motor1 200 steps, it moves until its encoder has reported 200 steps).
I'd like to find a way to overcome the backlash because currently my robot arm seems to get a stacking error every time it changes direction as a result of it having to 'catch up' through the backlash.
I was hoping to remedy this through my code rather then a mechanical solution, to save cost. Are there many known ways to do this?
One way to eliminate backlash is to always approach the target shaft position from the same direction of rotation.
That means in one of the directions of rotation, you have to overshoot the target and then move in reverse, back to the target.
For each axis mark a starting position then move x steps away and then x steps back. Note the difference and guess at difference in steps between where you are and where you want to be. Then try moving x steps away and x+y steps back to see if you come back to the start point. Repeat this adjusting y until it starts and ends at the correct place. Repeat this for the other direction and axis.
You then have a backlash value for each axis that needs applying if the movement is reversing direction from it's last move.
I used the technique that @Riva mentions for the stepper motors on my small lathe and it works very precisely - as measured with a dial test indicator.
...R
Thanks guys, I'll give it a go today!
Much appreciated
