(OXYMETER)Custom made MAX32664 not detected
Hello im making an OXYMETER for that I'm using Custom Made board and Custom made Sensor
Board-
S006D cktESP.pdf (165.9 KB)
SugarCheck.pdf (163.1 KB)
Sensor-
S003B) OXYMETER Schematic.pdf (131.4 KB)
Code-
#include <Wire.h>
#include "SparkFun_Bio_Sensor_Hub_Library.h"
SparkFun_Bio_Sensor_Hub bioHub;
  Wire.begin();
  delay(200); // Allow sensor to boot
  if (bioHub.begin() != 0) {
    Serial.println("MAX32664 not responding");
    while (1);
    Serial.println("MAX32664 initialized successfully");
  bioData data = bioHub.readBpm();
  Serial.print("Heart Rate: ");
  Serial.println(data.heartRate);
  Serial.print("SpO2: ");
  Serial.println(data.oxygen);
The output is MAX32664 not responding
What can I do to get the sensor values
What statement is issuing the error message.
EDIT: Never mind, I am blind sometimes.
I had a look at the example code that comes with the library and your code is different than the example. Maybe try the example first.
Scematics for all to see;
Tom.... :smiley: :+1: :coffee: :australia:
 This example sketch gives you exactly what the SparkFun Pulse Oximiter and
 Heart Rate Monitor is designed to do: read heart rate and blood oxygen levels.
 This board requires I-squared-C connections but also connections to the reset
 and mfio pins. When using the device keep LIGHT and CONSISTENT pressure on the
 sensor. Otherwise you may crush the capillaries in your finger which results
 in bad or no results. A summary of the hardware connections are as follows:
 SDA -> SDA
 SCL -> SCL
 RESET -> PIN 4
 MFIO -> PIN 5
 Author: Elias Santistevan
 Date: 8/2019
 SparkFun Electronics
 If you run into an error code check the following table to help diagnose your
 problem:
 1 = Unavailable Command
 2 = Unavailable Function
 3 = Data Format Error
 4 = Input Value Error
 5 = Try Again
 255 = Error Unknown
#include <SparkFun_Bio_Sensor_Hub_Library.h>
#include <Wire.h>
// Reset pin, MFIO pin
int resPin = 14;
int mfioPin = 16;
// Takes address, reset pin, and MFIO pin.
SparkFun_Bio_Sensor_Hub bioHub(resPin, mfioPin);
bioData body;
// What's this!? This is a type (like int, byte, long) unique to the SparkFun
// Pulse Oximeter and Heart Rate Monitor. Unlike those other types it holds
// specific information on your heartrate and blood oxygen levels. BioData is
// actually a specific kind of type, known as a "struct".
// You can choose another variable name other than "body", like "blood", or
// "readings", but I chose "body". Using this "body" varible in the
// following way gives us access to the following data:
// body.heartrate  - Heartrate
// body.confidence - Confidence in the heartrate value
// body.oxygen     - Blood oxygen level
// body.status     - Has a finger been sensed?
void setup(){
  Wire.begin();
  int result = bioHub.begin();
  if (result == 0) // Zero errors!
    Serial.println("Sensor started!");
    Serial.println("Could not communicate with the sensor!");
  Serial.println("Configuring Sensor....");
  int error = bioHub.configBpm(MODE_ONE); // Configuring just the BPM settings.
  if(error == 0){ // Zero errors!
    Serial.println("Sensor configured.");
  else {
    Serial.println("Error configuring sensor.");
    Serial.print("Error: ");
    Serial.println(error);
  // Data lags a bit behind the sensor, if you're finger is on the sensor when
  // it's being configured this delay will give some time for the data to catch
  // up.
  Serial.println("Loading up the buffer with data....");
  delay(4000);
void loop(){
    // Information from the readBpm function will be saved to our "body"
    // variable.
    body = bioHub.readBpm();
    Serial.print("Heartrate: ");
    Serial.println(body.heartRate);
    Serial.print("Confidence: ");
    Serial.println(body.confidence);
    Serial.print("Oxygen: ");
    Serial.println(body.oxygen);
    Serial.print("Status: ");
    Serial.println(body.status);
    // Slow it down or your heart rate will go up trying to keep up
    // with the flow of numbers
    delay(250);
I used example code. Now the led on the sensor is glowing but the output is constant
Heartrate: 0
Confidence: 0
Oxygen: 0
Status: 16
the values are not changing at all
Hi. @malharja123
Can you please post some images of your custom sensor?
here
Hi, @malharja123
Did you breadboard this before going to a custom PCB?
no it was working before as my sir said and it has been designed by him
