P10 led panel , help please
Hello, can anyone tell me what this model is and how it is programmed, which software, and which hardware. It would be very helpful to me very much. thank you
Can you provide more info about the system it’s connected in to?
Perhaps links to manuals, block diagram, websites etc?
The board looks like it may have a real-time clock and serial port, but that’s about it. At a guess, the serial connects back to a host controller, or is a standalone display controller receiving config & commands via serial..?
If the LEDs are indeed a matrix - those banks of pins may be row & column output drives, or possibly some shift data used to load ‘local’ driver boards at the panel.
damir27:
Model: HD-M v3.2
There should be a model number next to the serial port. Similar card below has it on upper left:
OPs pictures:
Front
Back
Closest thing I could find was a HD-M3
Huidu HD-M3 LED Display Controller
Model:HD-M3
Range:Single color: 64768 481024 321536 Dual color: 64384 48512 32768
Items:20PCS
Memory:2M byte
Communication:RS232 (communication line: 2-2 3-3 5-5 directly)
Areas:divided into 3 districts discretionarily
Effect: 200 types of boarder effects(classic + magic boarder); Supporting much more than 50 types of display
