I am unable to BT pair for anroid mobile with HC05, after clicking pair on mobile screen receiving error message "pairing rejected by HC05". please help
vin_swadi:
Did you put in the passcode for the HC-05 in your android app? Can you post your code and description of your project?
Power_Broker:
NO password,
here is code
- Bluetooh Basic: LED ON OFF - Avishkar
- Coder - Mayoogh Girish
- Website - http://bit.do/Avishkar
- Download the App :
- This program lets you to control a LED on pin 13 of arduino using a bluetooth module
char Incoming_value = 0; //Variable for storing Incoming_value
Serial.begin(9600); //Sets the data rate in bits per second (baud) for serial data transmission
pinMode(13, OUTPUT); //Sets digital pin 13 as output pin
if(Serial.available() > 0)
Incoming_value = Serial.read(); //Read the incoming data and store it into variable Incoming_value
Serial.print(Incoming_value); //Print Value of Incoming_value in Serial monitor
Serial.print("\n"); //New line
if(Incoming_value == '1') //Checks whether value of Incoming_value is equal to 1
digitalWrite(13, HIGH); //If value is 1 then LED turns ON
else if(Incoming_value == '0') //Checks whether value of Incoming_value is equal to 0
digitalWrite(13, LOW); //If value is 0 then LED turns OFF
vin_swadi:
NO password,
There's your problem (or, at least one of them) right there. HC-05's have a default password/pin of '1234' and this password/pin is required by the phone when pairing and connecting to the HC-05
