Paper feeder
I just wanna ask if someone already make like this one using printer rollers? please guide me. I wan't to make paper feeder for banknotes.
In how far is your banknote paper different from what the printer rollers are designed to feed?
This is a mostly mechanical problem, not related to Arduino. Once you completed your mechanism, add a motor to drive the rollers, a motor driver module, and start/stop sensors as required. Then write code to start and stop the motor, and come back with more specific problems.
the most technically difficult part of your project is the paper pick up and feed mechanism. the control of the mechanics is the easy part.
if you can make a paper feeder that uses a hand crank, you can add automation to it.
