Thank you yaafm! I really didn’t need the lenght. Right now I have this:
//ATTiny 85 and 74HC595 - 8Led POV stick.
//10K trimmer connected to A2, momentary switch connected to PIN3.
//Todo: switch changes between diffrent messages.
char text[] = "PASTA "; //String to be displayed
char text2[] = "MAGIC ";
int time = 0;
int time2 = 500;
//Pin connected to ST_CP of 74HC595
byte latchPin = 1;
//Pin connected to SH_CP of 74HC595
byte clockPin = 2;
////Pin connected to DS of 74HC595
byte dataPin = 0;
//character array created with GLCD Font Creator
char jada[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Code for char
0x00, 0x00, 0x06, 0x5F, 0x06, 0x00, // Code for char !
0x00, 0x07, 0x03, 0x00, 0x07, 0x03, // Code for char "
0x00, 0x24, 0x7E, 0x24, 0x7E, 0x24, // Code for char #
0x00, 0x24, 0x2B, 0x6A, 0x12, 0x00, // Code for char $
0x00, 0x63, 0x13, 0x08, 0x64, 0x63, // Code for char %
0x00, 0x36, 0x49, 0x56, 0x20, 0x50, // Code for char &
0x00, 0x00, 0x07, 0x03, 0x00, 0x00, // Code for char '
0x00, 0x00, 0x3E, 0x41, 0x00, 0x00, // Code for char (
0x00, 0x00, 0x41, 0x3E, 0x00, 0x00, // Code for char )
0x00, 0x08, 0x3E, 0x1C, 0x3E, 0x08, // Code for char *
0x00, 0x08, 0x08, 0x3E, 0x08, 0x08, // Code for char +
0x00, 0x00, 0xE0, 0x60, 0x00, 0x00, // Code for char ,
0x00, 0x08, 0x08, 0x08, 0x08, 0x08, // Code for char -
0x00, 0x00, 0x60, 0x60, 0x00, 0x00, // Code for char .
0x00, 0x20, 0x10, 0x08, 0x04, 0x02, // Code for char /
0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E, // Code for char 0
0x00, 0x00, 0x42, 0x7F, 0x40, 0x00, // Code for char 1
0x00, 0x62, 0x51, 0x49, 0x49, 0x46, // Code for char 2
0x00, 0x22, 0x49, 0x49, 0x49, 0x36, // Code for char 3
0x00, 0x18, 0x14, 0x12, 0x7F, 0x10, // Code for char 4
0x00, 0x2F, 0x49, 0x49, 0x49, 0x31, // Code for char 5
0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30, // Code for char 6
0x00, 0x01, 0x71, 0x09, 0x05, 0x03, // Code for char 7
0x00, 0x36, 0x49, 0x49, 0x49, 0x36, // Code for char 8
0x00, 0x06, 0x49, 0x49, 0x29, 0x1E, // Code for char 9
0x00, 0x00, 0x6C, 0x6C, 0x00, 0x00, // Code for char :
0x00, 0x00, 0xEC, 0x6C, 0x00, 0x00, // Code for char ;
0x00, 0x08, 0x14, 0x22, 0x41, 0x00, // Code for char <
0x00, 0x24, 0x24, 0x24, 0x24, 0x24, // Code for char =
0x00, 0x00, 0x41, 0x22, 0x14, 0x08, // Code for char >
0x00, 0x02, 0x01, 0x59, 0x09, 0x06, // Code for char ?
0x00, 0x3E, 0x41, 0x5D, 0x55, 0x1E, // Code for char @
0x00, 0x7E, 0x11, 0x11, 0x11, 0x7E, // Code for char A
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36, // Code for char B
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22, // Code for char C
0x00, 0x7F, 0x41, 0x41, 0x41, 0x3E, // Code for char D
0x00, 0x7F, 0x49, 0x49, 0x49, 0x41, // Code for char E
0x00, 0x7F, 0x09, 0x09, 0x09, 0x01, // Code for char F
0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A, // Code for char G
0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F, // Code for char H
0x00, 0x00, 0x41, 0x7F, 0x41, 0x00, // Code for char I
0x00, 0x30, 0x40, 0x40, 0x40, 0x3F, // Code for char J
0x00, 0x7F, 0x08, 0x14, 0x22, 0x41, // Code for char K
0x00, 0x7F, 0x40, 0x40, 0x40, 0x40, // Code for char L
0x00, 0x7F, 0x02, 0x04, 0x02, 0x7F, // Code for char M
0x00, 0x7F, 0x02, 0x04, 0x08, 0x7F, // Code for char N
0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E, // Code for char O
0x00, 0x7F, 0x09, 0x09, 0x09, 0x06, // Code for char P
0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E, // Code for char Q
0x00, 0x7F, 0x09, 0x09, 0x19, 0x66, // Code for char R
0x00, 0x26, 0x49, 0x49, 0x49, 0x32, // Code for char S
0x00, 0x01, 0x01, 0x7F, 0x01, 0x01, // Code for char T
0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F, // Code for char U
0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F, // Code for char V
0x00, 0x3F, 0x40, 0x3C, 0x40, 0x3F, // Code for char W
0x00, 0x63, 0x14, 0x08, 0x14, 0x63, // Code for char X
0x00, 0x07, 0x08, 0x70, 0x08, 0x07, // Code for char Y
0x00, 0x71, 0x49, 0x45, 0x43, 0x00, // Code for char Z
0x00, 0x00, 0x7F, 0x41, 0x41, 0x00, // Code for char [
0x00, 0x02, 0x04, 0x08, 0x10, 0x20, // Code for char BackSlash
0x00, 0x00, 0x41, 0x41, 0x7F, 0x00, // Code for char ]
0x00, 0x04, 0x02, 0x01, 0x02, 0x04, // Code for char ^
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, // Code for char _
0x00, 0x00, 0x03, 0x07, 0x00, 0x00, // Code for char `
0x00, 0x20, 0x54, 0x54, 0x54, 0x78, // Code for char a
0x00, 0x7F, 0x44, 0x44, 0x44, 0x38, // Code for char b
0x00, 0x38, 0x44, 0x44, 0x44, 0x28, // Code for char c
0x00, 0x38, 0x44, 0x44, 0x44, 0x7F, // Code for char d
0x00, 0x38, 0x54, 0x54, 0x54, 0x08, // Code for char e
0x00, 0x08, 0x7E, 0x09, 0x09, 0x00, // Code for char f
0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C, // Code for char g
0x00, 0x7F, 0x04, 0x04, 0x78, 0x00, // Code for char h
0x00, 0x00, 0x00, 0x7D, 0x40, 0x00, // Code for char i
0x00, 0x40, 0x80, 0x84, 0x7D, 0x00, // Code for char j
0x00, 0x7F, 0x10, 0x28, 0x44, 0x00, // Code for char k
0x00, 0x00, 0x00, 0x7F, 0x40, 0x00, // Code for char l
0x00, 0x7C, 0x04, 0x18, 0x04, 0x78, // Code for char m
0x00, 0x7C, 0x04, 0x04, 0x78, 0x00, // Code for char n
0x00, 0x38, 0x44, 0x44, 0x44, 0x38, // Code for char o
0x00, 0xFC, 0x44, 0x44, 0x44, 0x38, // Code for char p
0x00, 0x38, 0x44, 0x44, 0x44, 0xFC, // Code for char q
0x00, 0x44, 0x78, 0x44, 0x04, 0x08, // Code for char r
0x00, 0x08, 0x54, 0x54, 0x54, 0x20, // Code for char s
0x00, 0x04, 0x3E, 0x44, 0x24, 0x00, // Code for char t
0x00, 0x3C, 0x40, 0x20, 0x7C, 0x00, // Code for char u
0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C, // Code for char v
0x00, 0x3C, 0x60, 0x30, 0x60, 0x3C, // Code for char w
0x00, 0x6C, 0x10, 0x10, 0x6C, 0x00, // Code for char x
0x00, 0x9C, 0xA0, 0x60, 0x3C, 0x00, // Code for char y
0x00, 0x64, 0x54, 0x54, 0x4C, 0x00, // Code for char z
0x00, 0x08, 0x3E, 0x41, 0x41, 0x00, // Code for char {
0x00, 0x00, 0x00, 0x77, 0x00, 0x00, // Code for char |
0x00, 0x00, 0x41, 0x41, 0x3E, 0x08, // Code for char }
0x00, 0x02, 0x01, 0x02, 0x01, 0x00, // Code for char ~
0x00, 0x3C, 0x26, 0x23, 0x26, 0x3C // Code for char
// Serial.begin(9600);
time = (analogRead(2)/8); // trimmer sets the delay between column changes
kirjuta(text);
kirjuta(text2);
void kirjuta(char* ptr) { // the (pointer to the) string to be written to shift register
int place = 0; // variable for the table
int k=0;
while (ptr[k] != NULL) { //Seperates letters
place = (ptr[k++] - 32)*6; // My ASCII table starts from the 32nd letter and has 6 columns per letter.
for (int j=0; j<6; j++) { //for 6 columns
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, jada[place+j]);
digitalWrite(latchPin, HIGH);
delay(time2);
This doesn’t work… All the leds are on. That’s it.
But for debugging I used Nano and this code
void kirjuta(char* ptr) { // the (pointer to the) string and length of it
int k=0;
while (ptr[k] != NULL) { //Seperates letters, -1 removes NULL from the end.
Serial.println(jada[place+j], BIN);
// digitalWrite(latchPin, LOW);
// shiftOut(dataPin, clockPin, MSBFIRST, jada[place+j]);
// digitalWrite(latchPin, HIGH);
delay(time2);
Serial.println("-------END OF LETTER----------");
And it outputs
0
1111110
10001
10001
10001
1111110
0
100110
1001001
1001001
1001001
110010
So, the code is okay but somehow the shift register can’t get the information.
