below is some code ive started, so KeithRB I should just nest some if loops to take care of the conditions?...how do I jump out once the process has started?
thanks again for the help
Keg Washer
Uses mega2560 with 16 channel relay board to actuate ball valves to appropriate plumbing sources
int valves[] = {
2, 3, 4, 5, 6, 7, 8, 9, 10
}; // an array of pin numbers to which LEDs are attached
int pinCount = 9; // the number of pins (i.e. the length of the array)
int drain = 0;
int air = 1;
int hotH20 = 2;
int caustic = 3;
int acid = 4;
int sany = 5;
int co2 = 6;
int causticDrain = 7;
int acidDrain = 8;
char state = 0;
// the array elements are numbered from 0 to (pinCount - 1).
// use a for loop to initialize each pin as an output:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(valves[thisPin], OUTPUT); // sets as output
digitalWrite(valves[thisPin], HIGH); // turns relays off
//void(* resetFunc) (void) = 0;//declare reset function at address 0
// begin the keg washer cycle
while (Serial.available() > 0) {
// get incoming byte:
state = Serial.read();
// resetFunc(); //call reset
while (state == '1') {
digitalWrite(valves[drain], LOW); // open drain
Serial.println("open drain");
digitalWrite(valves[air], LOW); // purge air
Serial.println("purge air");
delay(10000);
digitalWrite(valves[air], HIGH); // air off
Serial.println("purge air off");
digitalWrite(valves[hotH20],LOW);// open hot rinse
Serial.println("open hot rinse");
delay(10000);
digitalWrite(valves[hotH20], HIGH); // close hot rinse
Serial.println("close hot rinse");
digitalWrite(valves[air], LOW); // open air purge
delay(10000);
digitalWrite(valves[air], HIGH); // close air purge
digitalWrite(valves[caustic], LOW); // open caustic supply
Serial.println("start caustic");
digitalWrite(valves[causticDrain], LOW); // open caustic return
Serial.println("open caustic return");
digitalWrite(valves[drain], HIGH); // close drain
Serial.println("close drain");
delay(30000);
digitalWrite(valves[caustic], HIGH);
Serial.println("close caustic");
delay(10000);
digitalWrite(valves[causticDrain], HIGH);
Serial.println("close caustic return");
delay(5000);
digitalWrite(valves[hotH20], LOW);
delay(10000);
delay(5000);
digitalWrite(valves[acid], LOW); // open caustic supply
digitalWrite(valves[acidDrain], LOW); // open caustic return
delay(30000);
digitalWrite(valves[acid], HIGH);
delay(10000);
digitalWrite(valves[acidDrain], HIGH);
delay(5000);
delay(10000);
delay(5000);
digitalWrite(valves[sany], LOW);
delay(15000);
digitalWrite(valves[sany], HIGH);
digitalWrite(valves[co2], LOW);
delay(5000);
delay(10000);
state = 48;
while(state== '0'){
Serial.println("all valves closed");
void serialEvent() {
