Hi guys. I made this code to send UDP via ethernet with an ethernet shield. to send a packet to a to a cue software to tell it which cue to to "go" depending on what distance the viewer is at. I'm using an ultrasonic sensor and since the ultrasonic sensor is constantly sending data when the viewer is in the same position the arduino will constantly be sending a packet to the software which is not what I want. I used delays to stop the arduino from sending too many packets but I basically just want the arduino to send a packet once until the distance is changed. So even if the viewer stays at a distance, only one packet will be sent. This is my code:
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <OSCMessage.h>
EthernetUDP Udp;
//the Arduino's IP
IPAddress ip(192, 168, 1, 21 );
//destination IP
IPAddress outIp(192, 168, 1, 20);
const unsigned int outPort = 53000;
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // you can find this written on the board of some Arduino Ethernets or shields
const int trig = 9;
const int echo = 8;
int duration = 0;
int distance = 0;
Ethernet.begin(mac,ip);
Udp.begin(53000);
pinMode(trig , OUTPUT);
pinMode(echo , INPUT);
digitalWrite(trig , HIGH);
delayMicroseconds(1000);
digitalWrite(trig , LOW);
duration = pulseIn(echo , HIGH);
distance = (duration/2) / 28.5 ;
Serial.println(distance);
if ( distance <= 7 )
delay(1);
//insert message here
OSCMessage msg("/cue/1/start");
msg.add((int32_t)analogRead(0));
Udp.beginPacket(outIp, outPort);
msg.send(Udp); // send the bytes to the SLIP stream
Udp.endPacket(); // mark the end of the OSC Packet
msg.empty(); // free space occupied by message
delay(2600);
else if ( distance <= 15 )
delay(1);
OSCMessage msg("/cue/2/start");
delay(3000);
else if ( distance <= 23 )
delay(1);
OSCMessage msg("/cue/3/start");
delay(6600);
else if ( distance <= 31 )
delay(1);
OSCMessage msg("/cue/4/start");
delay(7000);
@keganmiven, please edit your post, select all code and click the </> button to apply code tags; next save your post. That way we don't have to look at things like byte mac[] but it will be properly rendered as byte mac[] and indentations will be preserved. It also makes it easier to read and copy.
Next please read How to get the best out of this forum where the use of code tags is described.
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
- press Ctrl-T for autoformatting your code
- do a rightclick with the mouse and choose "copy for forum"
- paste clipboard into write-window of a posting
best regards Stefan
Thanks guys. I've edited my post. Sorry about that.
You define a new variable of type boolean.
After sending the first UDP-message the variable gets set to true
You code an if-condition that makes sending UDP-message dependend on that boolean variable
if( ! UDP_Msg_sended) {
sendUDP-message
if the distance changes the variable gets set false again
Is this rough description enough to get along or do you have more questions?
best regards Stefan
Hey Stefan. Thanks for the help. I've come up with something like this but am not sure where exactly to place it in my code. Thanks again.
you will get more, faster and better help if
you
post your best attempt how you tried to code it
best regards Stefan
Hey Stefan, Sorry about the long wait. Haven't had any time to touch my arduino up till now. I just managed to do it. Thank you for your help!
#include <SPI.h>
EthernetUDP Udp;
//the Arduino's IP
//destination IP
IPAddress outIp(192, 168, 10, 118);
byte mac[] = {
const int trig = 9;
const int echo = 8;
int duration = 0;
int distance = 0;
int cueNumber = 0;
Ethernet.begin(mac, ip);
Udp.begin(53000);
distance = (duration / 2) / 28.5 ;
{ if ( cueNumber != 1 )
delay(1);
cueNumber = 1;
delay(2600);
{ if ( cueNumber != 2 )
delay(1);
cueNumber = 2;
delay(3000);
{ if ( cueNumber != 3 )
delay(1);
cueNumber = 3;
delay(6600);
{ if ( cueNumber != 4 )
delay(1);
cueNumber = 4;
delay(7000);
else ( cueNumber = 0 );
