system
August 24, 2010, 10:28pm
1
I would like an Arduino to be able to turn a PC on or off - i.e short out the 2 pins on the motherboard which simulate a switch getting pushed in.
How can I achieve that? - has anyone else undertaken a similar project?
(i'm thinking of using web control with an ethernet shield)
Thanks,
Ian
system
August 24, 2010, 10:52pm
2
The wire at the on/off key is generally pulled-up to 5V by a 4.7k resistor from the standby supply of the ATX power supply. You can pull it down by at least three methods, depending on your personal level of paranoia:
direct connection to ground and any digital output.
a transistor inbetween
an optocoupler inbetween
Or a simple +5vdc low current reed relay. The Arduino controls the relay coil through a digital output pin and the relay contacts are free to wire across any existing switch contacts.
Example: http://www.allelectronics.com/make-a-store/item/RLY-541/5VDC-SPST-N.O.-DIP-REED-RELAY/1.html
Lefty
system
August 25, 2010, 12:25am
4
So funny... generally I am the one who recommends reed relais. However they are US$ 2 ....
Just a correction... There is a voltage devider involved so the pull-up is not to 5 but to around 3 volts. But that makes not much difference..
system
August 25, 2010, 8:01am
5
Thanks! - you dont know where there is a schematic for your idea do you deSilva?
Ian
