Hi!
Bin relativ neu in der Arduinoprogrammierung, daher entschuldigt bitte meine Unwissenheit!!!
Mit der Suche hatte ich bis jetzt leider keinen Erfolg.
Habe folgende Verständnisfrage: und zwar hab ich diesen Code auf http://www.neufeld.newton.ks.us/electronics/?p=241 im Internet gefunden:
- i2c_gpio
- Keith Neufeld
- May 26, 2008
- Prototype I2C interface to TI 9535 and 9555 GPIO expanders.
- Arduino analog input 5 - I2C SCL
- Arduino analog input 4 - I2C SDA
#include <Wire.h>
//#define DEBUG_GPIO
// I2C device address is 0 1 0 0 A2 A1 A0
#define DIP_ADDRESS (0x4 << 3 | 0x0)
#define LED_ADDRESS (0x4 << 3 | 0x7)
#ifdef DEBUG_GPIO
//Serial.println(DIP_ADDRESS); delay(2000);
#endif
Wire.begin();
gpio_write(LED_ADDRESS, 0xffff);
gpio_dir(LED_ADDRESS, 0x0000);
int bits;
#ifdef DEBUG_GPIO
Serial.println(0xff & gpio_read(DIP_ADDRESS));
#endif
bits = gpio_read(DIP_ADDRESS) & 0x0f;
// mirror direction of bits for output display
((bits & 1) << 3) | ((bits & 2) << 1) |
((bits & 4) >> 1) | ((bits & 8) >> 3)
) << 12);
#ifdef DEBUG_GPIO
delay(200);
#endif
#define REGISTER_INPUT (0)
#define REGISTER_OUTPUT (2)
#define REGISTER_CONFIG (6)
int gpio_read(int address) {
int data = 0;
// Send input register address
Wire.beginTransmission(address);
Wire.send(REGISTER_INPUT);
Wire.endTransmission();
// Connect to device and request two bytes
Wire.requestFrom(address, 2);
if (Wire.available()) {
data = Wire.receive();
data |= Wire.receive() << 8;
return data;
void gpio_dir(int address, int dir) {
// Send config register address
Wire.send(REGISTER_CONFIG);
// Connect to device and send two bytes
Wire.send(0xff & dir); // low byte
Wire.send(dir >> 8); // high byte
void gpio_write(int address, int data) {
// Send output register address
Wire.send(REGISTER_OUTPUT);
Wire.send(0xff & data); // low byte
Wire.send(data >> 8); // high byte
Und zwar geht es um folgenden abschnitt:
1 void gpio_dir(int address, int dir) {
2 // Send config register address
3 Wire.beginTransmission(address);
4 Wire.send(REGISTER_CONFIG);
5
6 // Connect to device and send two bytes
7 Wire.send(0xff & dir); // low byte
8 Wire.send(dir >> 8); // high byte
Vllt kann mir einer erklären was das 0xFF in Zeile 7 zu bedeuten hat!
Kann ich das nicht einfach weglassen???
Wenn ich das richtig verstehe ist doch Byte & 0xFF = Byte!?!?
Schon mal danke im vorraus!
LG Jan
