ive asked this already, but that answer apparently was not good enough…
im working with pcb’s now, and i picked up one that has each hole seperated (very common apparently), what i dont get is how u make connections between the holes… i tried to make like solder bridges on purpose, and they work but they r ugly and seem like a hassle for something that rly should be easier…
^^^ What he said. Bend the legs of resistors and caps to help form the “path” that you want to take.
I spend about a week trying this method, and found out it was MUCH (for me anyways) easier to just do a toner transfer PCB etch. Unless you don’t really care to go much beyond a breadboard set up, you’ll have to learn a PCB Cad program eventually. And eventually you want to learn the toner transfer method.
But the toner transfer method does require a few more tools:
Clothes Iron $20
Laser printer $100(used)
Copper clad boards (~$5 each for 4x6")
Drill press ($100-200)
PCB drill bits.($20)
Muriatic Acid $10 for a gallon
Hydrogen Peroxide $3
Actually, now that I think about it maybe the bread board solution isn’t all that bad!
I etch boards too, but occasionally I don’t want to go through the whole process and just launch into a proto board, designing it on the fly. Here’s an example using 30 gauge kynar wire. It’s not hard to do as long as you have a decent wire stripper, and maybe soft jaw pliers to grip the wire while you strip a tiny bit off the end. I usually make a dot of solder and then reheat the joint while stick the wire into it
