PCB internal power problem
Hi i Designed and milled a pcb for the Wemos D1
so far so good it workes
i did Ensure the internal 5V from the Wemos does not go to the PCB
But when i plug in the USB the LED on the PCB got on
so there is some 5V on the pcb from WEMOS
WHY and where does this come from
the internal “I+5V” right to X3 is not connected to the PCB Ofcause the 12V powersupply is not connected during programming so where does the 5V that lights up the LED come from ???
Please give me a “idee” where to search the pins are all not on the 5V line
Where is your schematic?
as a image or the entirer projekt eagle
here is the projekt eagle 7.6
sand_cheep_2025.zip (178.5 KB)
You have a powered Wemos and an unpowered PCB.
Your powered Wemos has active signal lines connected to your unpowered PCB.
You have sneak paths.
That's all I can speculate on in the absence of a schematic.
Good luck with your project.
this arend connected to the 5V VCC line so no power from there
sneak pads what dies this mean THERE are double outs for GPIO like SCL SDA /gpio14
they are not connected in the Board
