I'm planning to control 16 MOSFETs/transistors using either a PCF8575 or MPC23017 I/O i2c expander.
Additionally, I'll be using another I/O expander for a 4x4 keypad input matrix
(Also 8 input endstop switch )
So one pcf8575/mpc23017 for output and one for input
Questions:
- Initial State of PCF8575 Outputs:
- I've read that when a PCF8575 powers on, all outputs are initially high. Is there a way to mitigate this behavior, or does the MPC23017 have a different default state?
Also i read in forum that sometimes they can false make pins low/high because of noise. is this true?
- Input Matrix and Interrupts:
For the 4x4 keypad input matrix, I'm considering using interrupt pins to detect key presses and then read i2c data (so i dont make infinit loop). Is this a good approach?
Which I/O expander (PCF8575 or MPC23017) would be more suitable for output and input and why you think so?
Please share your recommendations and insights.
I'm open to suggestions and alternative approaches. Thank you for your help!
