// Example 52.1 PCF8591 DAC demo
// http://tronixstuff.com/tutorials Chapter 52
// John Boxall June 2013
#include "Wire.h"
#define PCF8591 (0x90 >> 1) // I2C bus address
Wire.begin();
for (int i=0; i<256; i++)
Wire.beginTransmission(PCF8591); // wake up PCF8591
Wire.write(0x40); // control byte - turn on DAC (binary 1000000)
Wire.write(i); // value to send to DAC
Wire.endTransmission(); // end tranmission
delay(10);
for (int i=255; i>=0; --i)
Wire.write(0x41); // control byte - turn on DAC (binary 1000000)
delay(10);
It works fine, but the voltage when measured on the VCC, SDA, or SLC pins are all 5.2V, yet when measuring @ VOUT the voltage maxes at 4.33V. Even if I hadcode
Wire.write(255);
which should be the max, I still get 4.33V.
My thought is that something is not right with the vref pin since it’s my understanding that’s what sets the max.
Ignore the PING((( sensor and LED as there for another project. Which still works as designed, but maxes at 4.33V. The picture shows a LittleBit bargraph and number module as this is part of the other project I’m working on. But I did measure with a multimeter as well for the above #s.
Ignore the MCP4725 DAC on the fritzing image as the outputs on the PCF8591 are very similar if not the same.
Any thoughts on whats going on here would be greatly appreciated!
Datasheet (page 14.2) states VOUT from Vss to Vdd with no resistive load, schematic of module shows VOUT connected to LED and 470R resistor so that is drawing 4 - 5 mA. Can you easily disconnect the LED and see if that lets VOUT get up to VDD ?
I should have said AOUT instead of VOUT.
I was looking at the schematic of the PCF8591 and the picture above it in your first post, the schematic shows D2 connected to AOUT thru a 470R resistor. The third pic shows the PCF8591 board with both LEDs burning, the fritzing diagram shows MCP4725 but no PCF8951. Which board do you have?
You are looking at a triangular waveform coming out of Aout.
What are you measuring the amplitude with?
If it is a DMM then 4.33V is probably right for a 5V signal.
TomGeorge:
Tom.....
If DMM is digital multimeter then yes and set to 20v DC.
Would I need an amplifier or something to get the signal to 5v?
Ultimately this will be part of a littlebits range sensor module. So when an object is at 2cm to the sensor I need to output 5v.
The output you are measuring is TRIANGULAR waveform, it is NOT DC, so your DMM is measuring the AVERAGE of the signal, which is varying from 0V to 5V in a TRIANGULAR waveform.
In DC mode a DMM is assumed to be measuring a CONSTANT voltage, TRIANGULAR is not.
This past haa a similar issue to mine where vout is 85% of vref.
My tests show another frustration: A lower than expected analog output voltage. For a 4.88 volt supply the output is only 4.17 volts (85%) at maximum value setting. Since the maximum supply voltage is 8 volts, increasing the supply to 6 volts may get a 5 volt result.
it appears that there's a 470 ohm resistor on R2 going to the D2 LED connected to AOUT. My thought is that it's this resistor that's lowering the AOUT from 5 to 4.2. I'm going to de-solder the pull up resistor when I get home and we'll see if the issues resolved.
jcallen:
You were right. I didn't understand which LED you were referring to. After learning about electronic symbols and reading over the diagram, I understood what you were talking about.
