PDM and I2C issues with Edge Impulse
Hello there everyone,
I have a trained model for audio classification, which works woderfully by itself.
And then I have an I2C set-up between the Nicla Sense ME(master) and Arduino Nano 33 Ble Sense(or Seeed Xiao Sense, tried with both, as slave). Which also works alone.
Here is the code for the I2C working between the 2 devices, a very simple i2c communication:
Master:
#include <Arduino.h>
#include "Nicla_System.h"
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
  while (Serial.available() > 0) {
    char incomingCharacter = Serial.read();
    if (incomingCharacter == '1') {
      Wire.beginTransmission(8); // transmit to device #8
      Wire.write(5);              // sends one byte
      Wire.endTransmission();    // stop transmitting
      delay(100);
And here for the slave:
#include <Wire.h>
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onRequest(requestEvent); // register event
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);    // start serial for output
// function that executes whenever data is received from master
void receiveEvent(int howMany) {
  while (Wire.available()){
   int x = Wire.read();    // receive byte as an integer
   if (x == 5){
    Serial.println("Hello World!");
Again, all of this code works.
Then my trained model had the void loop() edited so that it starts the recording and outputs the highest accuracy label and its accuracy, only after I send a 1 in the serial monitor (I am running record+classify, not continous):
      ei_printf("Starting...\n");
      delay(350);
      ei_printf("Recording...\n");
      bool m = microphone_inference_record();
      if (!m) {
        ei_printf("ERR: Failed to record audio...\n");
        return;
      ei_printf("Recording done\n");
      signal_t signal;
      signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
      signal.get_data = &microphone_audio_signal_get_data;
      ei_impulse_result_t result = { 0 };
      EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
      if (r != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", r);
        return;
      // print the predictions
      for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
        if (result.classification[ix].value > 0.5) {
          Serial.println("Highest Prediction Classifier is: " + String(result.classification[ix].label) + "\nAccuracy is: " + String(result.classification[ix].value, 2));
This code works wonderfully as well. Nothing else, with the exception of the shown void loop has been changed.
Then if I try to move to I2C, I have the master the same, but the slave with 2 different methods, like this:
  Serial.begin(115200);    // start serial for output
  while (Wire.available()) {
    Serial.println(x);
    if (x == 5) {
      delay(350);
      if (!m) {
        return;
      signal_t signal;
        return;
          //Wire.write(int(ix));
void requestEvent() {
  Wire.write(label); // respond with message of 1 byte
And also with the following method:
    Serial.println(x);
    if (x == 5) {
      delay(350);
      if (!m) {
        return;
      signal_t signal;
        return;
Neither work, it receives the byte, prints it out, prints that it starts recording and it seems to stop when it needs to start the recording:
Here is the full code:
#define EIDSP_QUANTIZE_FILTERBANK   0
/* Includes ---------------------------------------------------------------- */
#include <PDM.h>
#include <Wire.h>
#include <a1210_samples_cnn_voice_rec_inferencing.h>
/** Audio buffers, pointers and selectors */
typedef struct {
  int16_t *buffer;
  uint8_t buf_ready;
  uint32_t buf_count;
  uint32_t n_samples;
} inference_t;
static inference_t inference;
static signed short sampleBuffer[2048];
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
int label = 0;
   @brief      Arduino setup function
   @brief      Arduino main function. Runs the inferencing loop.
    int inByte = Wire.read();    // receive byte as an integer
    Serial.println(inByte);
    if (inByte == 5) {
      delay(350);
      if (!m) {
        return;
      signal_t signal;
        return;
          label = int(ix);
  Wire.write(label);
   @brief      PDM buffer full callback
               Get data and call audio thread callback
static void pdm_data_ready_inference_callback(void)
  int bytesAvailable = PDM.available();
  // read into the sample buffer
  int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
  if (inference.buf_ready == 0) {
    for (int i = 0; i < bytesRead >> 1; i++) {
      inference.buffer[inference.buf_count++] = sampleBuffer[i];
      if (inference.buf_count >= inference.n_samples) {
        inference.buf_count = 0;
        inference.buf_ready = 1;
   @brief      Init inferencing struct and setup/start PDM
   @param[in]  n_samples  The n samples
   @return     { description_of_the_return_value }
static bool microphone_inference_start(uint32_t n_samples)
  inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
  if (inference.buffer == NULL) {
    return false;
  inference.n_samples  = n_samples;
  inference.buf_ready  = 0;
  // configure the data receive callback
  PDM.onReceive(&pdm_data_ready_inference_callback);
  PDM.setBufferSize(4096);
  // initialize PDM with:
  // - one channel (mono mode)
  // - a 16 kHz sample rate
  if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
    ei_printf("Failed to start PDM!");
    microphone_inference_end();
    return false;
  // set the gain, defaults to 20
  PDM.setGain(127);
  return true;
   @brief      Wait on new data
   @return     True when finished
static bool microphone_inference_record(void)
  while (inference.buf_ready == 0) {
    delay(10);
  return true;
   Get raw audio signal data
static int microphone_audio_signal_get_data(size_t offset, size_t length, float *out_ptr)
  numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
  return 0;
   @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
  PDM.end();
  free(inference.buffer);
What makes it to be stuck is the while loop in the following function, more specifically the while loop:
    delay(10);
  return true;
I have written on the Edge Impulse forums as well, and I was pointed towards interrupting the I2C communication before the while happens, or using different mbed threads. As well as asking here as it seems to be an I2C issue.
I have tried using the Wire.end() and Wire.begin(8); with different methods (with end before the while loop and begin after). but nothing seems to work.
Meanwhile in regards to multiple Mbed threads, I have 0 experience on how I can do that.
I have tried 2 Arduino Nano 33 BLE Sense, 3 Seeed Xiao Sense, all have the same behaviour.
I also tried adding 4.7k pull-up resistors on the SDA/SCL pins (Although there are internal pull-up resistors already and the code without the voice recognition does work).
I would really appreaciate any help or ideas.
inference.buf_ready will never change. while goes forever.
This is the original code where interence.buf_ready changes, the function is the same, no changes:
#include <PDM.h>
typedef struct {
    int16_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
 * @brief      Arduino setup function
    Serial.println("Edge Impulse Inferencing Demo");
    // summary of inferencing settings (from model_metadata.h)
    ei_printf("Inferencing settings:\n");
    ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) / sizeof(ei_classifier_inferencing_categories[0]));
    if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
        ei_printf("ERR: Failed to setup audio sampling\r\n");
        return;
 * @brief      Arduino main function. Runs the inferencing loop.
    ei_printf("Starting inferencing in 2 seconds...\n");
    delay(2000);
    if (!m) {
        return;
    signal_t signal;
        return;
    ei_printf("Predictions ");
    ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
        result.timing.dsp, result.timing.classification, result.timing.anomaly);
    ei_printf(": \n");
        ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
    ei_printf("    anomaly score: %.3f\n", result.anomaly);
#endif
 * @brief      PDM buffer full callback
 *             Get data and call audio thread callback
        for(int i = 0; i < bytesRead>>1; i++) {
            if(inference.buf_count >= inference.n_samples) {
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
    if(inference.buffer == NULL) {
        return false;
        return false;
    PDM.setGain(127);
    return true;
 * @brief      Wait on new data
 * @return     True when finished
    while(inference.buf_ready == 0) {
        delay(10);
    return true;
 * Get raw audio signal data
    return 0;
 * @brief      Stop PDM and release buffers
    PDM.end();
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
not really
Here's the original:
        delay(10);
    return true;
And here is the same one copy-pasted that I use in my code:
    delay(10);
  return true;
It's literally the same function.
It seems you have misunderstood my point. The ISSUE in my code that WORKS is caused by the I2C interrups and PDM interrupts that happen together, it is a concurrency issue.
IF I change my code from I2C to UART for example, it works perfectly well, however I must use I2C. The interrupts are caused by the static bool microphone_inference_record(void) function which also uses the static bool microphone_inference_start(uint32_t n_samples) and static void microphone_inference_end(void).
it is a concurrency issue. really?
If you don't have a solution, and you haven't used the PDM library with Edge Impulse, in order to know how it works, I do not understand why the need to reply.
Such things happen in event handlers. Simply set a flag in the handler and do everything in loop() if the flag is set.
Hey @DrDiettrich, thanks for your reply, I have tested something similar, since I posted the issue here.
Here is the code (this is not the whole code there are some other functions specific to the voice recording and recognition but are unimportant here):
int label = 0;
bool startInferencing = false;
  Serial.println("I am waiting");
  while (startInferencing == false){
    Serial.println("I am blocking the code execution");
  Wire.end();
  Serial.println("Beginning Edge Impulse");
    return;
  ei_printf("Starting inferencing in 1 second...\n");
  if (!m) {
    return;
  signal_t signal;
    return;
  ei_printf(": \n");
      Serial.println("The label is: " + String(ix));
      label = int(ix);
    Serial.println(x);
    if (x == 5) {
      Serial.println("I am in the if section");
      startInferencing = true;
  Serial.println("I have exited the while");
  Serial.println("Info has been requested");
And this is the MASTER code, quite simple:
// Include Arduino Wire library for I2C
#include <Wire.h>
      Wire.requestFrom(8, 1);    // request 1 byte from slave device #8
      while (Wire.available()) { // slave may send less than requested
        int c = Wire.read(); // receive a byte as character
        Serial.print("Label Received : ");
        Serial.println(c);         // print the character
  delay(2000);
You can see the "startInferencing" flag that I use. It only works the first time though (only the onReceive function, it doesn't even reach the onRequest). By "it works" I mean, it receives the byte, it sets the flag, it starts the recording, it performs the classification, Serial.prints the classification, then it goes back to the main loop and gets stuck in the while false loop, and stays there, not listening to anything.
I have tried many different ways of checking for info and breaking the while loop, none worked. Any suggestions are appreacited. it seems that if I fix that, everything should work accordingly.
Stop using unnecessary loops and delay()s and Serial.print()s.
if (startInferencing) {...}
Do you really want to receive anything any more?
The wire.end is necessary, the way the PDM library is used by Edge Impulse, it creates interrupts, and when combined with the I2C interrupts, there is an issue. So the I2C is stopped, to perform the MIC recording, then the wire begins again. I do not need/will not be receiving anything throughout the recording phase.
As for the delays and Serial prints, they were used to check where the code was frozen, many of the Serial.prints come already from the Edge Impulse classifier. The Serial prints will be fully removed once the I2C communication between both devices works accordingly.
I cannot use an if with my code unless I flip the way the flag works. I will be trying that.
