huy guys,
i have a question about pe4302 breakout board
picture of pe4302 breakout board:
pe4302 datasheet:
http://www.psemi.com/pdf/datasheets/pe4302ds.pdf
at page 6 in table 6 "Parallel PUP Truth Table"
Table 6 states that if the latch is enabled then the attenuation is determined by C0.5-C16
and i dont understand two things
what is the switches in the breakout board?
(i want to determine the attenuation only by arduino software)
And second thing is about code i found
i think the code is the answer for the first question but i'm not sure I've got it right
i want to know if this code is fine and i can use it to control the attenuation with this code?
this is the code:
int LE = 2;
int CLOCK = 3;
int DATA = 4;
// The setup routine runs once when you press reset.
//Serial.begin(9600);
// Initialize pin as outputs.
pinMode(LE, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(DATA, OUTPUT);
// The loop routine runs over and over again forever.
int value; // Attenuation value, 0 through 31.
int ms = 1000; // How log to pause before next value (in msec)
// Step though each attenuation level pausing for 1 second at each
// value.
for (value = 0; value <= 31; value++) {
//Serial.print(value); Serial.println(" dB");
setAttenuator(value);
delay(ms); // wait for a second before repeating
for (value = 31; value >= 0; value--) {
Set attenuation level of PE4306 Digital Step Attenuator in serial
mode. Level is in range 0 to 31 dB. Do not call this at a rate
faster than 25 KHz (every 0.05 msec). Should work with other PE430x
series chips with minor changes. The code runs slowly enough that
we do not need to add any delays.
void setAttenuator(int value)
int level; // Holds level of DATA line when shifting
// Check for value range of input.
if (value < 0 || value > 31)
return;
// Initial state
digitalWrite(LE, LOW);
digitalWrite(CLOCK,LOW);
for (int bit = 5; bit >= 0; bit--) {
if (bit == 0) {
level = 0; // LSB is always zero
level = ((value << 1) >> bit) & 0x01; // Level is value of bit
digitalWrite(DATA, level); // Write data value
digitalWrite(CLOCK, HIGH); // Toggle clock high and then low
digitalWrite(CLOCK, LOW);
digitalWrite(LE, HIGH); // Toggle LE high to enable latch
digitalWrite(LE, LOW); // and then low again to hold it.
(this code is for PE4306 the Difference is PE4302 has 6bit and PE4306 has 5bit)
thanks in advance
