// This code is designed for Nano V.3
// this code is public domain, enjoy!
#include <Servo.h>
Servo ver;
Servo hor;
boolean replay = true;
unsigned long time_since_last_reset = 0;
 ver.attach(2);
 hor.attach(3);
 pinMode(4, OUTPUT);
 pinMode(13, OUTPUT);
void migrate(Servo &myServo, int newPos) {
 int wait=random(30,60); //random (40,60) (10,30)
 int pos = myServo.read(); //Read servo position
 if (pos < newPos) {
  for (int i=pos; i < newPos; i++) {
   myServo.write(i);
   delay(wait);
  for (int i=pos; i > newPos; i--) {
   myServo.write(i);
   delay(wait);
 Â
Â
void randomPosition() {
 int rand=random(20,100); //Horzontal range 80 deg
 migrate(hor, rand);
Â
 rand=random(85,110); //Vertical range around 25 deg
 migrate(ver, rand);
Â
  digitalWrite(4, HIGH); // turn the Laser on
  digitalWrite(13, HIGH); // turn onboard led on :-))
 randomPosition();
 delay(1500);
Â
digitalWrite(4, LOW);Â // turn the Laser off
digitalWrite(13, LOW);Â // turn onboard led off
ver.write(120);
hor.write(70);
if(millis() >= 500000)
while(1)
Like many... I've used a laser to fool my cats as well, but finally they got bored...
I probably have broken the 5-minutes limit too often :
I like your project, people probably won't buy a pair of servos, loose board etc. though.
As a usb-gadget with funny/better looking enclosure, a name like "personal cat fitness trainer", quite a lot of people may be interested...
Slightly modified and LED timer added. Shows how many minutes left, one LED for every minute.
// This code is designed for Nano V.3 by AndreasVan 2014-12-10
#include <Servo.h>
Servo ver;
Servo hor;
 ver.attach(2);
 hor.attach(3);
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
 pinMode(6, OUTPUT);
 pinMode(7, OUTPUT);
 pinMode(8, OUTPUT);
 pinMode(9, OUTPUT);
 if (pos < newPos) {
   myServo.write(i);
   delay(wait);
   myServo.write(i);
   delay(wait);
  Â
 migrate(hor, rand);
Â
 migrate(ver, rand);
Â
  digitalWrite(5, HIGH); // turn 5min led on
  digitalWrite(6, HIGH); // turn 4min led on
  digitalWrite(7, HIGH); // turn 3min led on
  digitalWrite(8, HIGH); // turn 2min led on
  digitalWrite(9, HIGH); // turn 1min led on
if(millis() >= 60000) // 5min
digitalWrite(5, LOW);Â // turn 5min led off
if(millis() >= 120000) // 4min
digitalWrite(6, LOW);Â // turn 4min led off
if(millis() >= 180000) // 3min
digitalWrite(7, LOW);Â // turn 3min led off
if(millis() >= 240000) // 2min
digitalWrite(8, LOW);Â // turn 2min led off
 randomPosition();
 delay(1500);
 digitalWrite(4, LOW); // turn the Laser off
 digitalWrite(9, LOW); // turn 1min led off
 digitalWrite(13, LOW); // turn onboard led off
ver.write(120);
hor.write(70);
if(millis() >= 300000) // 300.000 mili = 5 minutes
while(1)
I notice you already have a cat trainer on the background of your first picture, isn't it functional ?
I was thinking, a PIR motion sensor will probably be triggered by a cat as well. If you place one on the floor and read it with your arduino, your cat could operate the trainer by itself.
Simpson_Jr:
Unfortunately this trainer doesn't always work reliably
Simpson_Jr:
That's a good idea and will work with the dog too 8)
