Trying to make a PH sensor temperature compensated,
Cant be that simple, sketch likes it, but I'm sure its wrong lol
code
#include <NewSoftSerial.h>
NewSoftSerial mySerial = NewSoftSerial(2, 3);
char stamp_data[15];
byte holding;
byte i;
byte startup=0;
//declare variables
float tempC;
int tempPin = 0;
void setup(){
mySerial.begin(38400);
tempC = analogRead(tempPin); //read the value from the sensor
tempC = (5.0 * tempC * 100.0)/1024.0; //convert the analog data to temperature
Serial.print((byte)tempC); //send the data to the computer
delay(1000); //wait one second before sending new data
if(startup==0){
for(i=1; i <= 2;i++){
mySerial.print("l0");
mySerial.print(13,BYTE);
mySerial.print("l1");
startup=1;
mySerial.print(tempC); //I'm not sure this is right I changed it from “c” to tempC
if(mySerial.available() > 3) {
holding=mySerial.available();
for(i=1; i <= holding;i++){
stamp_data[i]= mySerial.read();
Serial.print(stamp_data[i]);
Serial.println("");
Ok never mind that,, I just need to try it 1st.
But I'm trying to add a little more code at the end and need help there.
what is the code for PH I know its not tempC
byte holding;
byte i;
byte startup=0;
//declare variables
float tempC;
int tempPin = 0;
void setup(){
if(startup==0){
startup=1;
Serial.println("");
if (tempC > 7) { // I need help, what is the code for PH I know its not tempC
digitalWrite(9, HIGH);
delay (1000);
digitalWrite(9, LOW);
delay (2*60UL*60UL*1000UL);
else {
This software was made to demonstrate how to quickly get your pH/ORP/DO/ stamp running on the Arduino platform.
An Arduino Duemilanove board was used to test this code.
Modify the code to fit your system. Code efficacy was NOT considered, this is a demo only.
To use this code you must add the "newsoftserial" library to your Arduino library folder.
The soft serial port TX line goes to the stamps RX pin.
The soft serial port RX line goes to the stamps TX pin.
Make sure you also connect to power and GND pins on the stamp to power and a common ground.
Data from the stamp is received and re-sent through the Arduinos hardware UART TX line.
Open TOOLS > serial monitor, set the serial monitor to the correct serial port and set the baud rate to 38400.
The data from the stamp will come out on the serial monitor
Download this code
#include <NewSoftSerial.h> //this will let the software take advantage of the "newsoftserial" library.
NewSoftSerial mySerial = NewSoftSerial(2, 3); //setup and rename soft uart.
//RX|TX
char stamp_data[15]; //this is where the data from the stamp is stored. The array is 15 char long because
//if no pH probe is connected, the message "check probe" is transmitted.
//Having an array that is too small will cause data corruption and could cause the Arduino to crash.
byte holding; //used to tell us the number of bytes that have been received by the Arduino and are
//holding in the buffer holding
byte i; //counter
byte startup=0; //used to control the start-up sequence
void setup(){
mySerial.begin(38400); //set up the soft serial to run at 38400
Serial.begin(38400); //set up the hardware serial port to run at 38400
void loop() { //main loop
if(startup==0){ //if the start-up sequence has not been run
for(i=1; i <= 2;i++){ //we go through this for-loop twice, turning on/ off the stamp leds
delay(1000); //wait 1 second
mySerial.print("l0"); //turn off the led
mySerial.print(13,BYTE); //ALWAYS end a command with <CR> (which is simply the number 13) or
// (print("/r")
mySerial.print("l1"); //turn on the led
//(print("/r")
startup=1; //stop the star-up loop from happening by setting the start-up var to 1
delay(1000); //after the stamp leds flashed twice, lets wait 1 second before we give the
// stamp a new command
mySerial.print("c"); //the command "c" will tell the stamp to take continues readings
//(print("/r")
//to take a single reading
//you would simple send the command
//mySerial.print("r");
//mySerial.print(13,BYTE);
//to take a temperature dependent reading
//send the temperature in celsius, let's say
//the temperature in celsius is 18.5
//mySerial.print("18.5");
if(mySerial.available() > 3) { //if we see the more than three bytes have been received by the Arduino
holding=mySerial.available(); //lets read how many bytes have been received
for(i=1; i <= holding;i++){ //we make a loop that will read each byte we received
stamp_data[i]= mySerial.read(); //and load that byte into the stamp_data array
for(i=1; i <= holding;i++){ //we now loop through the array
Serial.print(stamp_data[i]); //printing each byte we received through the hardware UART
Serial.println(""); //once we finished, we print a null char with the <CR><LF> command.
//declare variables
float tempC;
int tempPin = 0;
Serial.begin(9600); //opens serial port, sets data rate to 9600 bps
Well here's the thing I don't have all the parts yet, this is just part of a real long and complicated program.
Its an automated hydroponic garden. Fighting with those UPS guys in a big way, never ever ship anything UPS they suck USPS all the way.
Anyway all I want to know is the code for the PH part so I can Finnish.
