Photodiode Op-amp fluctuating
kataja:
But Arduino just saturates straight into 1023 or 5.00 volts.
double voltage = reading * 5.0 / 1023.0;
This assumes the Arduino supply is 5.0volt, which it rarely is.
You didn't tell us which Arduino you're using, and how you power the Arduino and opamp.
If this is a Nano on USB supply, then you will already see an A/D value of 1023 at ~4.6volt on the analogue input.
The A/D in default Aref mode is basically only suitable for ratiometric measurements.
For voltage measurements, you should use a more stable reference, like the internal 1.1volt Aref.
Leo..
Wawa:
Leo..
I use standalone "Arduino Duemilanove or Diecimila", ie. ATmega328P-PU in a breadboard https://www.arduino.cc/en/Main/Standalone .
I power both Arduino and op amp from my laptop USB via a regulator. DMM shows supply voltage of 5.00V. Since they are attached into the same power supply, Arduino should never measure over 4.98 volts from the op amp output. I think ratiometric measuring is actually OK in this case.
I replaced the ATmega328P-PU with another one, with same results. Voltage readings are consistently incorrect.
EDIT: AVCC is connected to 5V and VGND to GND, as they should.
It seems the inaccuracy was due to a poor quality breadboard: AVCC was floating! That caused the systematic error upwards!
