Photoresistor Module dead
Hello, Im here with my new photoresistor module sensor, it's looks great but nothing work as always with my new item dispatched!
I connect the 3 pin DOUT to Analog0, GND to GND and Vcc to 5V arduino.
Now I write down these simple code
//Constants
int pResistor = A0; // Photoresistor at Arduino analog pin A0
int ledPin=8;       // Led pin at Arduino pin 9
//Variables
int value;          // Store value from photoresistor (0-1023)
 pinMode(ledPin, OUTPUT);  // Set lepPin - 9 pin as an output
 pinMode(pResistor, INPUT);// Set pResistor - A0 pin as an input (optional)
  value = analogRead(pResistor);
  Serial.print("Lumen: ");
  Serial.println(value);
  //You can change value "25"
  if (value > 25)
    digitalWrite(ledPin, LOW);  //Turn led off
  else{
    digitalWrite(ledPin, HIGH); //Turn led on
  delay(500); //Small delay
But nothing work. My module have a screw and when I try to screw or unscrew change only the MAX value I guess from 1020 jump to 24.
I put some screenshot so you can understand better.
Anyone know how can I fix this problem and do sensor reactive to light?
Thanks
Use Aout to analog input.
The Dout (digital out) i can be set to signal at a predefined level. Adjust level with the potmeter..
knut_ny:
The module have only 3 pin Dout GND and Vcc
Looks like there's 2 versions of the module, the 4-pin version adds the analog output pin.
https://www.aliexpress.com/store/product/10pcs-lot-light-sensor-module-for-Arduino-digital-switch-sensors-High-precision-of-the-photocell/344644_1944430271.html
Anyways, your sensor isn't dead. It's digital only and appears to be working. Could just use a digital input pin to read the sensor (1 = HIGH, 0 = LOW). Then adjust the potentiometer so it triggers at the desired light level as suggested by knut_ny.
dlloyd:
Tee problem so is the potentiometer that doesn't work!
This night I will try again.
Thank you
The pot is a multiturn.. There may be as much as 20 full turns.
