Photosensor live value locks up after a button push.
Hello, thanks so much for any info.
When a button is pushed the photosensor's 'live' value of the sensor locks up, or seems store the value upon pushing a button, to trigger a sequence. The photosensor works as expected when reading it on the searial monitor.
Line 26, 87-89 are in question. Two variations have been tried and yield same result. Both codes attached.
I would like to see the code behave when the 'go' button is pushed, the code runs and waits for the photosensor trigger to happen, 0.5 seconds to 20 seconds, when the photosensor value is reached the trigger for the rest of the sequence happens.
-If the sensor is blocked (value of 390), the sequence preforms as desired.
-If the sensor is not blocked (value of 80) it will not trigger after the button push, blocking the sensor or not, does nothing to trigger it.
Variation to the code lines 26, 87-89 respectively:
int photosensor_val = 0; //val is used to store state of input pin
photosensor_val = analogRead(photosensor);
if (photosensor_val > 200) {
Code start:
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Servo.h>
/////////Pin Assignment////////////
#define return_button 2 //return button
#define go_button 3 //go button
#define photosensor A2 //Photoresistor
#define temp_sensor 59 // Sensor temp
#define left_pot A1 // left potentiometer
#define right_pot A0 // right potentiometer
#define pot A3 // potentiometer located in actuator
#define cooler 58 // cooler
#define bottom_motor_in1 4
#define bottom_motor_in2 5
#define bottom_motor_ctrl 9
#define push_motor_in1 7
#define push_motor_in2 8
#define push_motor_ctrl 10
#define motor_shield_enable 6
#define laser A12 //laser
float temperature_val = 0; //Variable to store the temperature in
int temperature_lowerLimit = 23; //define the lower threshold for the temperature
int temperature_upperLimit = 24; //define the upper threshold for the temperature
int counter = 0;
boolean break_flag = false;
OneWire oneWirePin(temp_sensor);
DallasTemperature sensors(&oneWirePin);
Servo flapper; //servo
// motor shield info: makerfabs OAS0000HB
// Bottom motor controll pin initiate;
pinMode(go_button, INPUT);
pinMode(return_button, INPUT);
pinMode(bottom_motor_in1, OUTPUT);
pinMode(bottom_motor_in2, OUTPUT);
pinMode(bottom_motor_ctrl, OUTPUT); // Speed control
// Push motor controll pin initiate;
pinMode(push_motor_in1, OUTPUT);
pinMode(push_motor_in2, OUTPUT);
pinMode(push_motor_ctrl, OUTPUT); // Speed control
//Enable the Motor Shield output;
pinMode(motor_shield_enable, OUTPUT);
digitalWrite(motor_shield_enable, HIGH);
pinMode(laser, OUTPUT); //laser
flapper.attach (46); //flapper(servo) pin 46
pinMode(photosensor, INPUT);
//cooler
pinMode(cooler, OUTPUT);
flapper.write (5); //flapper close ****to be at this position after reset.
//go button
if (digitalRead(go_button) == LOW) { //***GO button pushed
break_flag = false;
Serial.println("Go button pressed");
if (break_flag == false)
digitalWrite(laser, LOW); //laser on
flapper.write (65); // degrees flapper open
delay(50); //delay to allow led on and flapper to move,
sensor_checker();
Serial.println("flapper opened");
digitalWrite(motor_shield_enable, HIGH); //push motor down
analogWrite(push_motor_ctrl, analogRead(right_pot) / 4); //speed via POT
digitalWrite(push_motor_in1, HIGH);
digitalWrite(push_motor_in2, LOW);
Serial.println("Push motor runs");
sensor_checker();
if (analogRead(photosensor) > 200) { // 400>=450 if the sensor goes above 200 (lit reads: 115-118, Blocked is 297-307...
Serial.println("photosensor tripped");
digitalWrite(laser, HIGH); //laser off after photosensor is tripped.
Serial.println("bottom motor on");
analogWrite(bottom_motor_ctrl, analogRead(left_pot) / 4); //bottom motor on
digitalWrite(bottom_motor_in2, HIGH);
digitalWrite(bottom_motor_in1, LOW);
delay(1200);
sensor_checker();
sensor_checker();
Serial.println("flapper close");
Serial.println("push mtr up");
analogWrite(push_motor_ctrl, 255); //push motor up @ full speed
digitalWrite(push_motor_in1 , LOW);
digitalWrite(push_motor_in2, HIGH);
delay(250);
sensor_checker();
analogWrite(bottom_motor_ctrl, 0); //bottom motor off
digitalWrite(bottom_motor_in2, LOW);
delay(300);
sensor_checker();
digitalWrite(motor_shield_enable, LOW); //shield off
analogWrite(push_motor_ctrl, 0); //push motor off
digitalWrite(push_motor_in1, LOW);
flapper.write (5); //degrees flapper close
//potentiometer sensor function
if (analogRead(pot) > 900) // if the potentiometer goes below 600 (BOTTOM THEN RETURN TO TOP)...
analogWrite(push_motor_ctrl, 255); //push motor up full speed
break_flag = true;
sensor_checker();
//Return button
if (digitalRead(return_button) == LOW) { //*****Return button pushed
Serial.println("Return button pressed");
digitalWrite(motor_shield_enable , HIGH);
break_flag = true;
sensor_checker();
void sensor_checker() {
//cooler/temperature function
sensors.requestTemperatures();
temperature_val = sensors.getTempCByIndex(0);
if (temperature_val <= temperature_lowerLimit) { //lower limit
digitalWrite(cooler, LOW);
else if (temperature_val >= temperature_upperLimit) { //upperlimit
digitalWrite(cooler, HIGH);
V1.02C.ino (5.96 KB)
V1.03.ino (5.78 KB)
V1.03.ino (5.78 KB)
