Hi there,
Trying use the PID libraries but having some trouble generating Output that I would expect to see.
I would expect to see the PID Output set between the Output limits but what I get on the Serial Monitor is the PID algorithm giving me an output calculation directly on the inputvalues (in this case temperature). i.e with Kp set to 15, Input temp is 24 Deg C. Target temp is 60 DegC so the Output I see is (60-24)*15, where I would expect to see something in proportion to the Output limits.
All help appreciated
// PID Stuff
//Define variables we'll be connecting to.
double PIDOutput;
//Define the aggressive and conservative tuning parameters.
// double aggKp=15, aggKi=0.02, aggKd=40; //When input is below setpoint.
//test
double aggKp=15, aggKi=0, aggKd=0; //When input is below setpoint.
double consKp=15, consKi=0.1, consKd=40; // When input is above setpoint. P will not do anything since the output only drives in one direction.
//Specify the links and initial tuning parameters.
PID myPID(&chambertemp, &PIDOutput, &mainheattarget, consKp, consKi, consKd, DIRECT);
unsigned long PIDWindowSize = 60000;
unsigned long PIDwindowStartTime;
// Instance setups
MAX6675 ChamberSensor(SCK_PIN, CS_PIN, SO_PIN);
BlynkTimer DataSendTimerBlynk;
/* Blynk app Virtual pin numbers
V4 Heat Conntrol Manual Button
BLYNK_WRITE(V0)
mainheattarget = param.asInt();
Serial.println(mainheattarget);
BLYNK_WRITE(V4)
heatcontrolman = param.asInt();
// Blynk DataSendFunction temporary will send to serial need virtual blynk graph data
void DataSendBlynk()
chambertemp = ChamberSensor.readCelsius();
Serial.println("Deg C = ");
Serial.println(chambertemp);
Blynk.virtualWrite(V5, chambertemp);
Serial.println("PIDOutput = ");
Serial.println(PIDOutput);
Serial.println("PIDWindowSize = ");
Serial.println(PIDWindowSize);
Serial.println("Manual Control Button =");
Serial.println(heatcontrolman);
// Debug console
delay(5000);
// Pin assignments
pinMode(gassolenoid, OUTPUT);
pinMode(wificonnectOK, OUTPUT);
// Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
Blynk.connectWiFi(ssid, pass);
Blynk.config(auth, "blynk.cloud", 8080);
Blynk.disconnect();
// Blynk 1 second timer for sending data back to cloud
DataSendTimerBlynk.setInterval(1000L, DataSendBlynk);
if (WiFi.status() == WL_CONNECTED) {
Serial.println("WiFi connected OK");
digitalWrite(wificonnectOK, LOW);
Serial.println(ssid);
Serial.println("IP Address: ");
Blynk.connect();
if (Blynk.connected()) {
Serial.println("Blynk connect TRUE");
Serial.println("Main Loop");
// PID setup
PIDwindowStartTime=millis();
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, PIDWindowSize);
//turn the PID on
myPID.SetMode(AUTOMATIC);
Blynk.run();
if (heatcontrolman==1){
digitalWrite(gassolenoid, HIGH);}
{if(chambertemp>mainheattarget)
{ //We are over the setpoint set to normal.
myPID.SetTunings(consKp, consKi, consKd);
//We are not over, so we must be below. set to aggresive.
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
turn the output pin on/off based on pid output
unsigned long now = millis();
if (now - PIDwindowStartTime > PIDWindowSize)
{ //time to shift the Relay Window
PIDwindowStartTime += PIDWindowSize;
if (PIDOutput > now - PIDwindowStartTime) digitalWrite(gassolenoid, HIGH);
else digitalWrite(gassolenoid, LOW);
DataSendTimerBlynk.run();
