I had done my own code to control dc motor speed using PID. The code could calculate the speed of rpm unfortunately not giving a correct number. Secondly when the encoder disc of the motor attached to the optical sensor the disc rotate only once and then stop then continue rotate once and stop. Can you check my code and please advice me .
#include <PID_v1.h>
double Setpoint, Input, Output;
volatile int rpmcount = 0;
double rpm = 0;
unsigned long lastmillis = 0;
int outputPin = 9; // motor connected to digital pin 9 output
// Tuning parameters
float Kp=0; //Initial Proportional Gain
float Ki=10; //Initial Integral Gain
float Kd=0; //Initial Differential Gain
// Specify the links and initial tuning parameters
PID myPID(&rpm, &Output, &Setpoint,Kp,Ki,Kd, DIRECT);
const int sampleRate = 1;
unsigned long lastMessage = 0;
unsigned long serialTime;
Setpoint = 100;
attachInterrupt(0, rpm_motor, FALLING);//interrupt cero (0) is on pin two(2).
myPID.SetMode(AUTOMATIC); // Turn on the PID loop as automatic control
myPID.SetSampleTime(sampleRate); // Sets the sample rate
lastMessage = millis(); // timestamp
myPID.Compute(); // Run the PID loop
Output= 200;
analogWrite(outputPin, Output);
if (millis() - lastmillis >= 1000){ //Uptade every one second, this will be equal to reading frecuency (Hz).
detachInterrupt(0); //Disable interrupt when calculating
rpm = rpmcount * 60; // Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.
//input pid
Serial.print("RPM =\t"); //print the word "RPM" and tab.
Serial.print(rpm); // print the rpm value.
Serial.print("\t Hz=\t"); //print the word "Hz".
Serial.println(rpmcount); //print revolutions per second or Hz. And print new line or enter.
rpmcount = 0; // Restart the RPM counter
lastmillis = millis(); // Uptade lasmillis
attachInterrupt(0, rpm_motor, FALLING); //enable interrupt
void rpm_motor(){ // this code will be executed every time the interrupt 0 (pin2) gets low.
rpmcount++;
void SerialSend()
Serial.print("PID ");
Serial.print(Setpoint);
Serial.print(" ");
Serial.print(rpm);
Serial.print(" ");
Serial.print(Output);
Serial.print(" ");
Serial.print(myPID.GetKp());
Serial.print(" ");
Serial.print(myPID.GetKi());
Serial.print(" ");
Serial.print(myPID.GetKd());
Serial.print(" ");
if(myPID.GetMode()==AUTOMATIC) Serial.print("Automatic");
else Serial.print("Manual");
Serial.print(" ");
if(myPID.GetDirection()==DIRECT) Serial.println("Direct");
else Serial.println("Reverse");
[code]
//input pid
You are doing an awful lot with the interrupt handler detached. What really needs to happen with the interrupt handler detached? You need to make a copy of rpmcount and reset rpmcount to 0.
There's a good reason that function names on the Arduino use camelCase naming conventions. Variables should, too.
Really? Is that what that code is doing? I'd have never guessed.
Then why are you doing anything with PID? You need to fix this problem FIRST.
At first I used this code to calculate speed of motor with rpm and frequency. The code was working properly but when I modify the code by adding PID it doesnt give proper reading of the speed . Thats why seek your advice. This is my first code calculate speed of motor using rpm.
int rpm = 0;
int motorPin = 9; // motor connected to digital pin 9
int analogPin = 0; // potentiometer connected to analog pin 0
int val = 0; // variable to store the read value
pinMode(motorPin, OUTPUT); // sets the pin as output
val = analogRead(analogPin); // read the input pin
//analogWrite(motorPin, val / 4); // analogRead values go from 0 to 1023, analogWrite values from 0 to 255
rpmcount++;
}[code]
