PID Control in the presence of DC Motor Static Friction
Howdy all.
Been struggling with this for a week now, any advice or direction would be appreciated. I have an inverted pendelum mechanical system with a motor atop spinning a decent moment of inertia - the angular acceleration of this reaction wheel should balance the inverted pendulum (think self balancing bicycle robot etc) . For this I am using a PID control to control overshoot/provide smoothing and an overall balance. My issue is that the brushed DC motor, having that mass/moment of interia on the shaft, has some degree of static friction (output of 0-40 / 255 does not move the motor). This has proven very troublesome to overcome with the PID.
I have approached the problem by simply providing a deadband of +-40 so that any output value >0 is increased by 40, and any <0 is decreased by 40. This results in violent twitching of the system about the setpoint - progressively larger and violent overshoots. My goal is balance like this video (03:40):
https://www.youtube.com/watch?v=4kfBEaTncjI
I am using the same motor and motor controller as him as well. Any thoughts? Thanks guys
Another note: I think this setup has some nasty noise coming from the motor leads or something it's very common for the system to, upon a very rapid change in speed or direction and therefore an increased line current, go crazy and flash randomly between -255, 255, and 0 and trip my Supply safeties.
Here's a schematic of the wiring and my code:
Brushed (Geartrain) DC Motor Controlled by Ln298N motor driver
MPU6050 Gyro/Accel
Arduino Nano
12V DC Power Supply (Suppling 14V to overcome 2V drop by Ln298N)
#include "I2Cdev.h"
#include <PID_v1.h>
#include "MPU6050_6Axis_MotionApps20.h"
MPU6050 mpu;
bool dmpReady = false;
uint8_t mpuIntStatus;
uint8_t devStatus;
uint16_t packetSize;
uint16_t fifoCount;
uint8_t fifoBuffer[64];
Quaternion q;
VectorFloat gravity;
float ypr[3];
double setpoint = 178.5;
double Kp = 10;
double Kd = 0;
double Ki = 0;
double torqueOffset = 40;
double accelerometerAngle = 0;
const double alpha = 0.98;
const int IN1 = 8;
const int IN2 = 7;
const int EN1 = 9;
double input, output;
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
volatile bool mpuInterrupt = false;
void dmpDataReady()
    mpuInterrupt = true;
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    devStatus = mpu.dmpInitialize();
    mpu.setXGyroOffset(45);
    mpu.setYGyroOffset(46);
    mpu.setZGyroOffset(64);
    mpu.setXAccelOffset(-1468);
    mpu.setYAccelOffset(716);
    mpu.setZAccelOffset(639);
    if (devStatus == 0)
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        packetSize = mpu.dmpGetFIFOPacketSize();
        pid.SetMode(AUTOMATIC);
        pid.SetSampleTime(1);
        pid.SetOutputLimits(-255 + torqueOffset, 255 - torqueOffset);
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    pinMode(IN1, OUTPUT);
    pinMode(IN2, OUTPUT);
    digitalWrite(IN1, LOW);
    digitalWrite(IN2, LOW);
double adjustedOutput = 0;
double lastPitch = 0;
    if (!dmpReady)
        return;
    while (!mpuInterrupt && fifoCount < packetSize)
        pid.Compute();
        Serial.print(input);
        Serial.print("\t");
        Serial.print(output);
        if (output > 0)
            adjustedOutput = output + torqueOffset;
            adjustedOutput = output - torqueOffset;
        Serial.print("\t");
        Serial.println(adjustedOutput);
        if (input > 120 && input < 250)
            if (adjustedOutput > 0)
                Forward();
            else if (adjustedOutput < 0)
                Reverse();
            adjustedOutput = 0;
            Stop();
    fifoCount = mpu.getFIFOCount();
    if ((mpuIntStatus & 0x10) || fifoCount == 1024)
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    else if (mpuIntStatus & 0x02)
        while (fifoCount < packetSize)
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        fifoCount -= packetSize;
        mpu.dmpGetQuaternion(&q, fifoBuffer);
        mpu.dmpGetGravity(&gravity, &q);
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
        input = ypr[1] * 180 / M_PI + 180;
    //prevent motor from rapidly occilating between -255, 0, and 255 randomly once PID output calls for 255 or -255
    if (currentMillis >= 1000)
        if (abs(input - lastPitch) > 100.00)
            while (true)
                Stop();
    lastPitch = input;
void Forward()
    digitalWrite(IN1, HIGH);
    analogWrite(EN1, adjustedOutput);
    Serial.print("F");
void Reverse()
    digitalWrite(IN2, HIGH);
    analogWrite(EN1, adjustedOutput * -1);
    Serial.print("R");
void Stop()
    Serial.print("S");
Deadband violates a very basic principle of PID theory, as it is discontinuous.
Given that you currently have Kd and Ki set to zero, it appears that you need to spend some time learning how to tune the PID algorithm. There are tutorials on line, easily found with the search phrase "PID tuning".
Also spend some time studying other people's projects. It has long been understood that PWM motor control is nonlinear.
Hey
Thanks, my D and I are zero because I have been constantly playing with values to tune. I'm posting to here because I haven't found anything to overcome the static friction for use with PID - if I use the normal PID to overcome this the gain becomes massive to 'instantly' overcome this stall friction. Without any accommodation any normal PID will think that the system is reacting (in the -40 to 40 output when the motor isnt actually moving) when in reality it is not...
Most people tune systematically, rather than "playing". Good luck with your project.
That was a paraphrase lol, I have been methodically changing values for a trial and error tune
Is the calculation here for the Yaw or the Pitch? I thought ypr[1] would be the Pitch, but the calculation seems to be for the Yaw.
Yeah, the orientation of my board has the yaw changing and determining the displacement angle, I just call it pitch for nomenclature.
I've seen self-balancing robots that use motor speed encoders along with a separate PID controller for the motor speed (in addition to the PID for the tilt). Have a look here, for example. Not sure what this buys you.
