PID Line follower
Dear All I used some one else program to run my PID line follower so it does not travel on the line please advice any issue with my modified codes
#define Left_Dir1 5
#define Left_Dir2 7
#define Left_Speed 6
#define Right_Dir1 2
#define Right_Dir2 4
#define Right_Speed 3
#define buzzer A4
#define button A5
int sensor[5] = { 8, 9, 10, 11, 12 }; // Pin assignment
int sensorReading[5] = { 0 }; // Sensor reading array
float activeSensor = 0; // Count active sensors
float totalSensor = 0; // Total sensor readings
float avgSensor = 3.0; // 4.5 Average sensor reading
//72                     //8 2.5           255/2.5    72
float Kp = 102;   // Max deviation = 6-3.5 = 2.5 ||  255/3.5 = 102
float Ki = 0.00015;//0.00015
float Kd = 5;//5
float error = 0;
float previousError = 0;
float totalError = 0;
float power = 0;
int PWM_Right, PWM_Left;
void setup(){
  Serial.println( "test");
  pinMode(Left_Dir1, OUTPUT);
  pinMode(Left_Dir2, OUTPUT);
  pinMode(Left_Speed, OUTPUT);
  pinMode(Right_Dir1, OUTPUT);
  pinMode(Right_Dir2, OUTPUT);
  pinMode(Right_Speed, OUTPUT);
  for (int i = 0; i < 5; i++) {
    pinMode(sensor[i], INPUT);
  Stop();
  Forward();
void loop(){
 lineFollow();
void Forward(){
  digitalWrite(Left_Dir1, LOW);
  digitalWrite(Left_Dir2, HIGH);
  digitalWrite(Right_Dir1, LOW);
  digitalWrite(Right_Dir2, HIGH);
void Stop(){
  analogWrite(Left_Speed, 0);
  analogWrite(Right_Speed, 0);
void PID_program(){
  readSensor();
  previousError = error; // save previous error for differential
  //Serial.println( previousError);
  //4.5
  error = avgSensor - 3.0; // Count how much robot deviate from center
  totalError += error; // Accumulate error for integral
  //Serial.println( totalError);
  power = (Kp * error) + (Kd * (error - previousError)) + (Ki * totalError);
  //Serial.println( power);
  if ( power > 255 ) {
    power = 255.0;  //255.0
  if ( power < -255.0 ) {
    power = -255.0;  //-255.0
  if (power < 0) // Turn left
    PWM_Right = 255;//255
    PWM_Left = 255 - abs(int(power));//255
  else // Turn right
    PWM_Right = 255 - int(power);//255
    PWM_Left = 255;//255
void lineFollow(void) {
  PID_program();
  analogWrite(Left_Speed, PWM_Left);
  analogWrite(Right_Speed, PWM_Right);
void readSensor(void) {
    sensorReading[i] = !digitalRead(sensor[i]);
    Serial.println( sensorReading[i]);
    if (sensorReading[i] == 1) {
      activeSensor += 1;
    totalSensor += sensorReading[i] * (i + 1);
  avgSensor = totalSensor / activeSensor;
  activeSensor = 0; totalSensor = 0;
void testSensor(void) {
  for (int i = 0; i < 8; i++) {
    Serial.print(!digitalRead(sensor[i]));
  Serial.println("");
  delay(20);
boolean checkSensor() {
  boolean state = 0;
    if (digitalRead(sensor[1]) == 0) {
      state = 1;
  return state;
Please edit your post to include code tags ("</>" button).
Describe what it does instead.
Post a description of your robot, including a circuit diagram.
jremington:
For sensor
I am using this king of sensors ( % Sensor ) directly connected to arduino pins in the following https://www.google.lk/search?q=IR+SENSOR+LINE+FOLLOWER&biw=1280&bih=891&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjCxKWD8Y_MAhXJlJQKHR8wDFQQsAQIGQ#imgrc=NWSjTy8AMwSLLM%3A
  sensor[0]=digitalRead(8);
  sensor[1]=digitalRead(9);
  sensor[2]=digitalRead(10);
  sensor[3]=digitalRead(11);
  sensor[4]=digitalRead(12);
For Motor driver
I am using this kind of L298 Motor driver directly connected to arduino https://www.google.lk/search?q=l298n+motor+driver&biw=1280&bih=891&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiP-oLS8Y_MAhWFKJQKHbVkClQQ_AUIBigB#imgrc=EfHIg427WR0M1M%3A
#define Left_Dir1 7
#define Left_Dir2 5
Please advice
