Line follower pid didnt work
Please help me troubleshoot my code. My line following robot didnt work, even though it normally work when i used normal line follower code .
Im using two drv8833 motor driver for controling 4 3v dc motor and 5 tcrt5000 ir sensor
Here's my code
#define NUM_SENSORS 5
#define TIME_INTERVAL 10
#define LF1_Motor 8
#define LF2_Motor 7
#define LB1_Motor 6
#define LB2_Motor 5
#define RF1_Motor 12
#define RF2_Motor 11
#define RB1_Motor 10
#define RB2_Motor 9
int s[6], total, sensor_position;
int threshold = 600;
float avg;
int position[6] = {1, 2, 3, 4, 5};
int set_point = 3;
  pinMode(LF1_Motor, OUTPUT);
  pinMode(LF2_Motor, OUTPUT);
  pinMode(LB1_Motor, OUTPUT);
  pinMode(LB2_Motor, OUTPUT);
  pinMode(RF1_Motor, OUTPUT);
  pinMode(RF2_Motor, OUTPUT);
  pinMode(RB1_Motor, OUTPUT);
  pinMode(RB2_Motor, OUTPUT);
  Stop();
  delay(2000);
  //displayValue();
 PID_LINE_FOLLOW();
void Sensor_reading(){
  sensor_position = 0;
  total = 0;
  for(byte i = 0; i < 5; i++){//sensor data read from A1, A2, A3, A6, A7
    if (i > 2){
      s[i] = analogRead(i + 3);
    }else{
      s[i] = analogRead(i);
    if (s[i] > threshold) s[i] = 1; //analog to digital conversion
    else s[i] = 0;
    sensor_position += s[i] * position[i];
    total += s[i];
  if (total) avg = sensor_position / total; //average value
void PID_LINE_FOLLOW(){
  int kp = 50, kd = 500, PID_Value, P, D;
  float error, previous_error;
  int baseSpeed = 200, leftSpeed, rightSpeed, turnSpeed = 100;
  char t;
  while (1){
    Sensor_reading();
    error = set_point - avg;
    D = kd * (error - previous_error);
    P = error * kp;
    PID_Value = P + D;
    previous_error = error;
    //adjusting motor speed
    rightSpeed = baseSpeed - PID_Value;
    leftSpeed = baseSpeed - PID_Value;
    motor(leftSpeed, rightSpeed);
    Sensor_reading();
    if (total == 0){
      if (t != 's'){
        if (t =='r') motor(turnSpeed, -turnSpeed);
        else motor(-turnSpeed, turnSpeed);
        while (!s[2]) Sensor_reading();
    if (s[0] && !s[4]) t = 'l';
    if (s[4] && !s[0]) t = 'r';
    else if (total == 5){
      Sensor_reading();
      if (total == 5){
        motor(0, 0);
        while (total == 5) Sensor_reading();
      } else if (total == 0) t = 's';
void displayValue(){
    if (i > 2){
    }else{
    Serial.print(String(s[i]) + " ");
  delay(50);
void motor(int a, int b){
  if (a > 0){
    digitalWrite(RF1_Motor, LOW);
    digitalWrite(RF2_Motor, HIGH);
    digitalWrite(RB1_Motor, LOW);
    digitalWrite(RB2_Motor, HIGH);
  }else{
    a = -(a);
    digitalWrite(RF1_Motor, HIGH);
    digitalWrite(RF2_Motor, LOW);
    digitalWrite(RB1_Motor, HIGH);
    digitalWrite(RB2_Motor, LOW);
  if (b > 0){
    digitalWrite(LF1_Motor, LOW);
    digitalWrite(LF2_Motor, HIGH);
    digitalWrite(LB1_Motor, LOW);
    digitalWrite(LB2_Motor, HIGH);
  }else{
    b = -(b);
    digitalWrite(LF1_Motor, HIGH);
    digitalWrite(LF2_Motor, LOW);
    digitalWrite(LB1_Motor, HIGH);
    digitalWrite(LB2_Motor, LOW);
  if (a > 200) a = 200;
  if (b > 200) b = 200;
  analogWrite(RF1_Motor, a);
  analogWrite(RF2_Motor, a);
  analogWrite(LF1_Motor, b);
  analogWrite(LF2_Motor, b);
  analogWrite(RB1_Motor, a);
  analogWrite(RB2_Motor, a);
  analogWrite(LB1_Motor, b);
  analogWrite(LB2_Motor, b);
void Stop(){
What exactly do you mean by that ?
What does it do ?
What should it do ?
It should follow black line, but it didnt move at all
If it didn't move then how could it follow the black line ?
Do you mean that it detects the black line but does not move ?
Yes. It should detect a black line and follow it.
Because the sensor and motor are working normally, so i think its the program that has a problem
Is it detecting the black line ?
Yes. But the motor dont move or just making a high pitch noise
What values are being sent to the motor ?
[quote="orangbiasa, post:1, topic:1275974"]
The motor get it values from here
    P = error * kp;
    PID_Value = P + D;
It would be an analog input
That is where the speeds are derived from but what values do the calculations result in ?
Im sorry i didnt know what that mean
Please give me an example
Try printing rightSpeed and leftSpeed before sending them to the motors
It keep sending 200 values non stop
The next step is to print the results of the intermediate values of the speed calculation
I got values range from -2050 to 1325
Which variables had those values and do they seem reasonable ?
Is this trying to read pins 0, 1, 2, 5, and 6? I think they need to be prefixed with "A" to be the analog input pins.
Its the PID_Value variable, i think because of that the left and rightMotor values will stagnant on 200
I dont know how to fix that
I see, how should i change it?
It is like analogRead(A(3 + i) ?
