PID LOOP and AFMOTOR (v1) Shield FOR ARDUINO Not working
Hey guys! I would like to thank anyone beforehand for any help they can give me. This is my first attempt at using Arduino or programming in general. I will try my best to be as descriptive as possible.
Before I state my problem I'd like to describe what it is I am doing. I want to create a simple PID lopp using Arduino's PID LIBRARY and control a 12v DC FAN motor. I have the fan connected to a motor shied (model in link) that I want to adjust the speed of the fan using the pid loop. I have a Hall effect sensor connected to the bottom of a arm that is blown by the fan. The pid loop has a setpoint that puts a magnetic as close to the Hall sensor as possible. I will enclose a picture of the setup for reference:
I know everything is connected correctly because I see the sensor readings in the Serial Monitor Pane:
Here is a pic of my desktop with the Serial Monitor Open:
On the right is the Output from the PID Loop and the left is the analog Hall Effect Sensor:
I also know the motor works correctly because when I use the sample code from the AFmotor library called MotorTest the fan spools up.
Here is my Code that I'm working on:
 * PID Basic Example
 * Reading analog input 0 to control analog PWM output 3
//Library packages required
#include <PID_v1.h>
#include <AFMotor.h>
//define the variable, PIN_OUTPUT 3 may not be needed?
#define PIN_INPUT A5
#define PIN_OUTPUT 3
AF_DCMotor motor(4);
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp=.5, Ki=.05, Kd=.05;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, REVERSE);
  motor.setSpeed(200);
  motor.run(RELEASE);
//initialize the variables we're linked to
  Input = analogRead(PIN_INPUT);
  Setpoint = 10;
//turn the PID on
  myPID.SetMode(AUTOMATIC);
//Setup the Serial Monitor Output correctly
  Serial.print("Input");
  Serial.print("\t");
  Serial.print("Output");
//initiate PID LOOP
// READ analog values from Hall Effect Sensor
  Input = analogRead(PIN_INPUT)-388;
 //Send the Value to the Serial Monitor for debugging
  Serial.print(Input);
  Serial.print("\t");
 //Allow the PID LIBRARY to compute the values,
  myPID.Compute();
 // The output value from the my.PID.Compute function will now be put into the motor.setSpeed command
  motor.setSpeed(Output);
//Tell the motor to turn on and spin up using the value from the seSpeed command
  motor.run(REVERSE);
// Print the PID Output to Serial Monitor for debugging
  Serial.print(Output);
Any help would be greatly appreciated, Here is a link to a youtube video describing what Im trying to do in more detail.
PID is good for making an Input value match a Setpoint value. I'm don't know if it is suitable for maximizing an Input value. The PID needs to know if increasing Output will increase or reduce Input. When you are trying to maximize the Input the direction you change Output will depend on which side of the peak you are on.
Maybe someone can suggest a control algorithm that is suitable for maximizing.
johnwasser:
I may be explaining this incorrectly. I have enclosed a Youtube video explaining it a little better:
UPDATE**
The problem has been resolved. The code above did work, apparently one of the "H-bridges" on the motor had failed. When I changed the motor leads to a different output the problem resolved itself.
I'm very happy!
