Hello, I am working on PID temperature fan controller which cools down the material with a dc motor fan until the thermistor gets voltage of the setpoint at desired temperature. However, I keep getting Output=0 after myPid.Compute(). The hardware is not a problem as the fan and the thermistor work individually. Could you please tell me what the problem is?
Thank you for your help.
#include <PID_v1.h>
double Setpoint, Input, Output;
float Kp = 100, Ki = 15, Kd = 2;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int thermistor = A0;
int Vo;
float R1 = 10000;
float logR2, R2, T, Tc, Tf;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
float t;
int speedPin = 5;
int dir1 = 4;
int dir2 = 3;
int mSpeed = 255;
pinMode(thermistor, INPUT);
pinMode(speedPin, OUTPUT);
pinMode(dir1, OUTPUT);
pinMode(dir2, OUTPUT);
Vo = analogRead(thermistor);
Input = map(Vo, 0, 1023, 0, 255);
Setpoint = map(495, 0, 1023, 0, 255);
myPID.SetMode(AUTOMATIC);
myPID.SetOutputLimits(0,255);
Vo = analogRead(thermistor); // Convert the voltage into the temperature
R2 = R1 * (1023.0 / (float)Vo - 1.0);
logR2 = log(R2);
T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
T = T - 273.15; // Until here
t = t + 0.5; // Measuring time for later calculation for PID characteristics
myPID.Compute();
digitalWrite(dir1, HIGH);
digitalWrite(dir2, LOW);
analogWrite(speedPin, Output);
// Serial.print("Thermistor Voltage: ");
// Serial.print(Vo);
// Serial.print("V ");
// Serial.print("Temperature: ");
// Serial.print(T);
// Serial.println(" C");
// Serial.print("Output: ");
// Serial.println(Output);
// Serial.print("- Time: ");
// Serial.print(t);
// Serial.println("s");
Serial.print("Input: ");
Serial.print(Input);
Serial.print(", Output: ");
Serial.print(Output);
Serial.print(", Setpoint: ");
Serial.println(Setpoint);
