Piezo not playing full melody
hi,
so I am trying to make my piezo play "What makes You Beautiful" by One Direction and I have translated the notes from the sheet music so they readable by the pitches.h library but for some reason when I run the program the piezo only plays the first few notes in the melody.
This is the code I've made for the song, I have it in a different tab because I am coding six songs and it is easier to have them in separate tabs. Also some are commented out because I was getting the memory error.
[void Song4() {
lcd.setCursor(1, 0);
lcd.print("Now playing...");
lcd.setCursor(0, 1);
lcd.print(" WMYB");
// notes in the melody:
int melody[] = {
NOTE_E4, 0, NOTE_E4, NOTE_E4, 0, NOTE_E4,
NOTE_DS4, 0, NOTE_DS4, 0, NOTE_DS4, 0, NOTE_DS4,
NOTE_DS4, NOTE_DS4, NOTE_DS4, NOTE_E4, NOTE_E4, NOTE_E4,
NOTE_E4, 0, 0, NOTE_E4, NOTE_E4, NOTE_E4,
NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_FS4,
NOTE_GS4, NOTE_FS4, 0, NOTE_E4, NOTE_E4, NOTE_E4
//NOTE_E4, 0, 0, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, 0, 0, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4, NOTE_E4,
//NOTE_FS4, NOTE_GS4, NOTE_GS4, 0, 0, NOTE_E4, NOTE_GS4, NOTE_B4, NOTE_CS5, NOTE_CS5, NOTE_B4, NOTE_GS4, NOTE_GS4, NOTE_GS4, NOTE_GS4, NOTE_FS4,
//NOTE_E4, NOTE_GS4, NOTE_B4, NOTE_CS5, NOTE_CS5, NOTE_B4, NOTE_GS4, NOTE_FS4, 0, NOTE_GS5, NOTE_FS5, NOTE_E5,
// NOTE_E5, NOTE_E5, NOTE_E5, NOTE_E5, NOTE_GS5, NOTE_FS5, NOTE_FS5, 0, NOTE_GS5, NOTE_FS5, NOTE_E5, NOTE_E5, NOTE_FS5, NOTE_GS5, 0,
//NOTE_GS5, NOTE_GS5, NOTE_GS5, NOTE_GS5, NOTE_GS5, NOTE_FS5, NOTE_E5,
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
4, 8, 8, 4, 8, 8,
4, 8, 8, 8, 8, 8, 8,
4, 8, 8, 4, 8, 8,
4, 4, 8, 8, 8, 8,
4, 4, 8, 8, 8, 8,
4, 4, 8, 8, 8, 8,
4, 8, 8, 4, 8, 8, 8,
8, 4, 8, 8, 8, 8,
//4, 8, 8, 8, 8, 8, 4, 8, 8, 8, 8, 8, 4, 8, 8, 4, 8, 8,
// 8, 8, 4, 4, 4, 4, 8, 8, 4, 8, 8, 4, 8, 4, 4, 6,
// 4, 8, 8, 4, 8, 8, 6, 8, 8, 8, 8,
// 4, 4, 4, 4, 4, 8, 8, 8, 8, 8, 8, 4., 8, 4, 4,
// 8, 8, 8, 8, 6, 6, 6,
int thisNote = 0;
int size = sizeof(melody) / sizeof(int);
// to calculate the note duration, take one second
// divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
for (int thisNote = 0; thisNote < 8; thisNote++) {
int noteDuration = 1000 / noteDurations[thisNote];
tone(8, melody[thisNote], noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
noTone(8); // stop the tone playing:
} // end for
Song4title();
Please edit your post to add code tags, as described in the "How to use this forum" post (then the smilies will go away).
Make sure that the code you post is a complete Arduino program that reproduces the error.
Just the first 8 notes perhaps?
Steve
What is this for?
The variable size isn't used anywhere.
MK1888:
What is this for?
But should be... in place of that '8' no doubt...
