Ping sensor and speaker
Ive have stitched together this code just for fun to try to make some sound experiments with ping sensors. This however get boring quite fast. :slight_smile: You might have some suggestions to further experiments? Thanks alot!
const int pingPin = 7;
int soundpin = 9;
  pinMode(soundpin, OUTPUT);
  long duration, inches, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  cm = microsecondsToCentimeters(duration);
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
   int level = cm;
    level = map(level, 0, 40, 100, 400);
    if(cm < 40){
       tone(9, level);
    else {
      noTone(9);
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
Instead of playing like a slide-whistle you could have a list of note frequencies and use the distance to pick from the list. You could use a pentatonic scale (C D E G & A) and they will all sound good together.
Equal-Tempered tuning [A4 = 440Hz]
Octave=1 Octave=2 Octave=3 Octave=4 Octave=5 Octave=6
A 55.000 110.000 220.000 440.000 880.000 1,760.000
C 65.406 130.813 261.626 523.251 1,046.502 2,093.005
E 82.407 164.814 329.628 659.255 1,318.510 2,637.020
G 97.999 195.998 391.995 783.991 1,567.982 3,135.963
