Pins 5 and 6: controlled by Timer 0 in PWM mode unwanted
I am using an arduino Lilypad Simplesnap with atmega328p. I need a PWM on pin 5. I use the timer 0 to generate it and it works great. However, I am supposed to use pin 6 as a digital OUTPUT to enable and disable a device.
The problem is that Pins 5 and 6 are BOTH controlled by Timer 0. Therefore the PWM of pin 5 influences the behavior of pin 6.
How can I make pin 5 generate a PWM and pin 6 just be a digital OUTPUT?
I attached two picture of the behavior of pin 6 with and without PWM on pin 5.
Thanks in advance.
Sphinx:
Only if you enabled PWM output on pin 6.
Does the noise on pin six affect the enable/disable? What are you controlling with pin 6?
In regards to the processor, Pin 6 as an input/output is independent of pin 5. Pin six should just be a digital output. The interaction is some sort of noise and nothing fundamental to using one pin as pwm and the other as standard digital output.
Can you put a low pass filter on the pin 6 output and still control the enable/disable?
Did you connect the grounds?
It is set as INPUT. It a good remark though because if it is set as OUTPUT the PWM is on both pins.
cattledog:
Actually I can control pin 6 despite the noise. The thing is that I use 6 digital pins for 6 identical devices and only pin 6 displays this noise that is oddly similar to the PWM frequency. I tried swapping the devices and the noise remains.
MorganS:
I checked the grounds are connected.
Thank you all for the responses!
Which leaves four possibilities...
  1. You are not correctly operating the oscilloscope
  2. The processor is damaged
  3. You have a connection between the two pins
  4. There is bug in your code
The fourth is, by far, the most likely.
Only if the timer set up has enabled the pwm hardware output on both pins. Perhaps the default ide behavior for the lilypad is different than other AT328 devices, but I doubt it.
Have you changed the timer setup to a different pwm frequency?
I bought another arduino and it works better. It is a hardware issue.
Problem solved.
