Hi folks, I am done with my programming skills and it is still not working properly therefore it is time to ask the experts.
My project is pretty simple:
I want to control my door opening with two sensors:
Outside will use a RFID module (RC522) to identify the card
inside will use a Motion Sensor (PIR am312) to see when I approach and release the door.
They do work individually, but together don't.
Maybe I am missing the programming logic here on the "IFs/else"?
Any help will be much appreciated, here is the code:
int pinopir = 3; //Pin PIR
int acionamento; //sensor variable
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
pinMode(pinopir, INPUT); //Define pino sensor input
pinMode(LED_BUILTIN, OUTPUT);
pinMode(2, OUTPUT);
Serial.begin(9600); // start a serial
SPI.begin(); // start SPI bus
mfrc522.PCD_Init(); // start MFRC522
acionamento = digitalRead(pinopir); //read sensor PIR
if (acionamento == LOW)
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
// Procura por cartao RFID
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
Serial.println("Ola FILIPEFLOP !");
digitalWrite(2, HIGH); // ativa rele, open door
delay(3000); // wait 3 sec
digitalWrite(2, LOW); // desativa rele, close door
// Seleciona o cartao RFID
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Mostra UID na serial
Serial.print("UID da tag :");
String conteudo= "";
byte letra;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
conteudo.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
conteudo.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Mensagem : ");
conteudo.toUpperCase();
if (conteudo.substring(1) == "74 A9 4E 43") //UID 1 - Cartao
Serial.println("Ola Cartao 1 !");
digitalWrite(2, HIGH); // ativa rele, abre a trava solenoide
delay(2000); // espera 3 segundos
digitalWrite(2, LOW); // desativa rele, fecha a trava solenoide
if (conteudo.substring(1) == "A7 BA 80 26") //UID 2 - Cartao
Serial.println("Ola Carteo 2 !");
if (conteudo.substring(1) == "4D 6C B5 63") //UID 3 - Cartao
Serial.println("Ola Cartao 3 !");
if (conteudo.substring(1) == "76 B5 64 1F") //UID 4 - Cartao
Serial.println("Ola Cartao 4 !");
