Rfid Card and Burglar Alarm with PIR sensor
Hi everybody, i tried to a solution on web especially at forum.arduino.cc but i couldn't find so i decide to start a new topic.
My project is that :
I make a model house, little one. Out of door, i have a rfid card reader and a id card. I set up all functions of RFID library, i can read id card, open door with servo motor,close after 5 seconds. I try to make a burglar system, i can detect abnormal access which is not done use door(burglar).
But problem is that, when i do a normal access to home with my id card, i have to push a button in 10 seconds to close alarm system (pır motion sensor and buzzer). If i don't push the button in 10 seconds alarm will work and buzzer will sound.
My code is here :
//Kart oku_LCD_SERVO
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#include <LiquidCrystal.h>
const int rs = 47, en = 46, d4 = 45, d5 = 44, d6 = 43, d7 = 42;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define SS_PIN 53
#define RST_PIN 5
#define PIR 10
#define Buzzer 9
#define buton 2
int PIR_deger;
int buton_deger;
unsigned long ilkZaman;
unsigned long sonZaman;
unsigned long zaman;
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
Servo myServo; //define servo name
  lcd.begin(16, 2);
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  myServo.attach(8); //servo pin!!!!
  myServo.write(0); //servo start position
///led buz
  lcd.setCursor(0, 0);
  lcd.println("Karti Okutun :    "); // Read card
  pinMode(Buzzer, OUTPUT);
  pinMode(PIR,INPUT);
  pinMode(buton, INPUT);
  digitalWrite(Buzzer,LOW);
  PIR_deger=digitalRead(PIR);
  Serial.println(PIR_deger);
if( (  ! mfrc522.PICC_ReadCardSerial() ) && PIR_deger ==HIGH)
    lcd.clear();
    lcd.println("HIRSIZZZZ!!!    "); // There are unwanted access.
    lcd.setCursor(0, 1);
    lcd.println("VARRR!!!!!!!!   ");
    digitalWrite(Buzzer,HIGH);
    delay(3000);
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
     return ;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return ;
  //Show UID on lcd
  lcd.clear();
  lcd.print("UID tag :");
  delay(1500);
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     lcd.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     lcd.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
     delay(1500);
  lcd.clear();
  lcd.println("Sonuc : ");
  content.toUpperCase();
  PIR_deger=digitalRead(PIR);  // PIR_deger = value of pır
  delay(2000);
  if (content.substring(1) == "AE 4C 54 20") // Is it aviable idendity card?
    lcd.setCursor(8, 0);
    lcd.println("Giriniz ");
    myServo.write(180);     // Door open
    delay(5000);
    myServo.write(0);  // Door close
    if(buton_deger == LOW)   // buton deger= value of button, high or low
    ilkZaman=millis();      // Measure (ilkZaman = firsttime) time when buton is low
    Serial.print("ilk zaman : "); // Write on the Serial Port to see whether is it true.
    Serial.println(ilkZaman);
/*  PIR_deger=digitalRead(PIR);
  Serial.print("PIRRR : ");
  delay(500);*/
  buton_deger = digitalRead(buton);  // Is button high? (buton_deger = situation of button?
//  delay(30);
  if( buton_deger == HIGH  )    // It is not wait to read button is high, it is keep going to down, i measure all time 0 ms.
    sonZaman=millis();
    Serial.print("Son zaman : ");
    Serial.println(sonZaman);
    zaman= (sonZaman-ilkZaman); // zaman = time -- time= LastTime-FirstTime i mean it is elapsed time between high and low
Serial.println(zaman);
    if(buton_deger == HIGH && zaman<=10000) // button is high && time<10000 ms = 10 seconcds
    PIR_deger = LOW;  // turn off pır motion sensor
  if(buton_deger == HIGH &&  zaman>10000) button is high but i didn't push within 10 second
    PIR_deger = HIGH;           // if i push after 10 seconds, pır will high and buzzer will sound.
    delay(3000);
    digitalWrite(Buzzer, LOW);
// Down is not important, i have second card and it will work to show wrong id card.
 if(content.substring(1) != "AE 4C 54 20")
    lcd.clear();
    lcd.setCursor(8,0);
    lcd.print("Gecersiz");
    delay(100);
    delay(100);
    delay(100);
    delay(1500);
    lcd.clear();
Main problem is that, if(button ==HIGH) loop is not waiting, and i miss it. So i measure elapsed time between high and low time is zero.
Thanks for all your helps. I read how to use this forum and start a new topic, if i made a mistake please tell me, i will fix immediately.
An if statement is not a looping construct, so the whole idea of it waiting is impossible.
Your loop() function starts with an unconditional delay(). Of course you are going to miss switch presses. Your code can have NO delay()s. Anywhere.
Thanks for your answering.
Sir, i know it is not a loop but my english is not very well. I'm so sorry, you are right, i couldn't explain myself.
Can you give me an advice to solve problem, i can't solve although i tried somethings.
I did. Get rid of the delay() calls.
The loop() function needs to be called over and over again, quickly, so you don't miss important events, like switch presses and PIR sensor changes.
Knowing that someone broke in twenty minutes after they've gone doesn't seem useful. Knowing that they've broken in instantly, would be. Get rid of the delay()s to make the response much more instantaneous.
