Play music with an buzzer by Matlab
would you like to help me playing music in Matlab. there are lots of example to play on IDE but I couldn't find a code to play a ton by Matlab.
What are you having trouble with? I assume you want to use MATLAB to generate/play music in real-time while the Arduino is connected to the computer?
I assume you know how to use MATLAB? (I'm not a MATLAB user.)
If you can figure-out to how to send data from MATLAB to the serial port, you can use one or more of the Arduino [u]serial read commands[/u] to read the information/commands into your Arduino sketch.
But WHY do this??? If you're running MATLAB on a computer, your computer has a soundcard with more sound capability than the Arduino... And, with the computer you'd have the option of using MIDI (if MIDI is applicable to what you're doing.)
@DVDdoung thanks for answering.
I'm not a professional Matlab user too.
the main problem is how can I regenerate this code to Matlab
int melody[] = { C, b, g, C, b, e, R, C, c, g, a, C };
int beats[] = { 16, 16, 16, 8, 8, 16, 32, 16, 16, 16, 8, 8 };
so I'm looking for an example.
tnx.
