What Update ?
Where's the DFRobot mp3 player?
Where's your effort?
This Pause next prev available on net . . .
Bit complex coding
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
# define ACTIVATED LOW
int buttonPause = 2;
int buttonPrevious = 3;
int buttonNext = 4;
boolean isPlaying = false;
void setup () {
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
mySerial.begin (9600);
playFirst();
isPlaying = true;
void loop () {
if (digitalRead(buttonPause) == ACTIVATED)
if(isPlaying)
pause();
isPlaying = false;
}else
isPlaying = true;
play();
if (digitalRead(buttonNext) == ACTIVATED)
if(isPlaying)
playNext();
if (digitalRead(buttonPrevious) == ACTIVATED)
if(isPlaying)
playPrevious();
void playFirst()
execute_CMD(0x3F, 0, 0);
setVolume(20);
execute_CMD(0x11,0,1);
void pause()
execute_CMD(0x0E,0,0);
void play()
execute_CMD(0x0D,0,1);
void playNext()
execute_CMD(0x01,0,1);
void playPrevious()
execute_CMD(0x02,0,1);
void setVolume(int volume)
execute_CMD(0x06, 0, volume); // Set the volume (0x00~0x30)
delay(2000);
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
mySerial.write( Command_line[k]);
Just got this link and anyhow manage to write down code from the running clip
Its with analog input but code is showing errors
#include "DFRobotDFPlayerMini.h"
#include "BigButton.h"
DFRobotDFPlayerMini player;
softwareSerial.begin(9600);
if(player.begin(softwareSerial))
Serial.printIn("OK");
Serial.printIn("FAIL!");
player.volume(30);
processButton(bigGreenButton, "green", 7, 30);
processButton(bigRedButton, "red", 5, 30);
int trackPlaying = -1;
void processButton(BigButton & bigButton, char * txt, int trackNo, int intVolume)
switch (bigButton.checkButton())
case BUTTON_UP:
Serial.print(txt);
Serial.printIn(" up");
case BUTTON_UP_DOWN:
Serial.print(txt);
Serial.print(player.available());
Serial.printIn(" mid down");
case BUTTON_DOWN:
Serial.print(txt);
Serial.printIn(" down");
if (trackPlaying != trackNo)
player.volume(intVolume);
player.play(trackNo);
trackPlaying = trackNo;
player.stop();
WE HAVE TO MAKE IT FOR DIGITAL INPUTS AND WITH REASONABLE THINGS WITHIN CODE
PLEASE CHECK THE SCRIPT AS I AM NOT SURE IF I HAVE NOTED IT DOWN CORRECTLY VIA FRAMES OF THE CLIP
When attempting a new thing, I always begin at the beginning.
I try to master a concept, make sense of one thing and then I move on.
Start small, work your way Up.
Press a button → Play a track.
Ya exactly i used to do so . . . That's why i used to apply the code @43 by modifying it for a single track play with single push button but here for this
void processButton its showing errors . .
suppose i go this way
player.volume(30);
case BUTTON_UP:
Serial.print(txt);
player.stop();
Then also i am getting errors at the points where i am not able to understand the issues
And too i am not getting anything like such examples of single track play viz push button other than that you tube example . . . But trying for some other way to find any related article
please help me in getting that
Why do you (Why would anybody) need a thing like bigbutton.h ?
No idea what he did . . . I got it on you tube link i shared @43
Here the simplest code i designed from all the collections till now & it's getting uploaded with no errors but unable to function anything there
int buttonPlay = 2;
//int buttonPause = 3;
//int buttonPrevious = 4;
void setup () {
pinMode(buttonPlay, INPUT);
void loop () {
if (digitalRead(buttonPlay) == LOW)
player.play("Track 3");
Other than this i am not getting anything yet
Trying as per my reach
The tracks on the microSD have to be titled after their scheme.
001.wav, 002.wav, 003.wav
A name (or whatever) can be added after the numbers (001dog.wav, 002car.wav, 003bell.wav).
I see . .
So this time i am on simple list of few mp3 songs so how should i script ?
001songname.mp3 ???
001.wav
In the root, not a folder.
OK So for an mp3 file also we need to make extension as .wav ??
Sorry - right, MP3 (001.mp3).
ok sure le me check
Well, is the code all the way right in rest of the places ?
Please comment if anything left here . .
I am on it right now
No its not working still . . .
What's next step on it ?
Final last code is like this
int buttonPlay = 2;
void setup () {
void loop () {
player.play("003.mp3");
//#include "Arduino.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
mySoftwareSerial.begin(9600);
Serial.begin(115200); // change to whatever you need/like
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true){
delay(0); // Code to compatible with ESP8266 watch dog.
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(10); //Set volume value. From 0 to 30
//myDFPlayer.play(1); //Play the first mp3
void loop ()
delay(5000); // assuming your track is short
Does this "play" anything at all?
If 'No', note any error messages printed in Serial Monitor.
Its the output of serial monitor
Yes, and. . .
Nothing else
No change with player related actions
