Hi.
Trying to play a soundfile from SD-card as the title suggest. Using mainly the code from the "Simple audio player"-tutorial. I used the setup from the SD-card sketch as the initializing of the card-part failed in the original sketch. Here's my full sketch:
Simple Audio Player for Arduino Zero
Demonstrates the use of the Audio library for the Arduino Zero
Hardware required :
* Arduino shield with a SD card on CS4
* A sound file named "test.wav" in the root directory of the SD card
* An audio amplifier to connect to the DAC0 and ground
* A speaker to connect to the audio amplifier
Arturo Guadalupi <a.guadalupi@arduino.cc>
Angelo Scialabba <a.scialabba@arduino.cc>
Claudio Indellicati <c.indellicati@arduino.cc>
This example code is in the public domain
http://arduino.cc/en/Tutorial/SimpleAudioPlayerZero
// include the SD library:
#include <SPI.h>
#include <SD.h>
#include <AudioZero.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 28;
int track;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
while (1);
Serial.println("Wiring is correct and a card is present.");
// 44100kHz stereo => 88200 sample rate
AudioZero.begin(2*44100);
int count = 0;
// open wave file from sdcard
File myFile = SD.open("test.wav");
if (!myFile) {
// if the file didn't open, print an error and stop
Serial.println("error opening test.wav");
while (true);
Serial.print("Playing");
// until the file is not finished
AudioZero.play(myFile);
Serial.println("End of file. Thank you for listening!");
while (true) ;
Tried replicating everything in the original tutorial but receive the following in the serial monitor:
20:47:27.555 ->
20:47:27.555 -> Initializing SD card...Wiring is correct and a card is present.
20:47:27.555 -> error opening test.wav
If i run the SD card test sketch this is what i get:
20:56:29.874 ->
20:56:29.874 -> Initializing SD card...Wiring is correct and a card is present.
20:56:29.874 ->
20:56:29.874 -> Card type: SDHC
20:56:29.874 -> Clusters: 242304
20:56:29.874 -> Blocks x Cluster: 64
20:56:29.874 -> Total Blocks: 15507456
20:56:29.874 ->
20:56:29.874 -> Volume type is: FAT32
20:56:29.874 -> Volume size (Kb): 7753728
20:56:29.874 -> Volume size (Mb): 7572
20:56:29.874 -> Volume size (Gb): 7.39
20:56:29.874 ->
20:56:29.874 -> Files found on the card (name, date and size in bytes):
20:56:29.874 -> BOOM-B~1.WAV 2016-05-08 09:05:36 55680732
20:56:29.874 -> SDFHJK.WAV 2016-05-08 08:13:20 1245224
20:56:29.874 -> TEST.WAV 2020-03-01 19:48:54 1748127
Tried searching for details regarding the audiozero library to figure out what is what but can't find much information. Would love some help.
Cheers
AP
