Is there a diagram explaining the various communication modes configurable in the PLC IDE?
Is it possible to do Modbus TCP via wifi or only using the ethernet port?
Does the Communication setup apply to sending code to the Arduino PMC, or is that handled elsewhere? I am commonly running into issues with errors trying to connect to the board where the target device is selected as ArduinoPMC1.0 but shows '' in the build window, and similar for the ARM processor.
Trying to map a PLC tag to a Modbus address results in an error and no tags are shown, is this a 1.0 issue that will be fixed in 1.1?
The PLC IDE is basically unusable with the current documentation.
