I am using the Portenta Machine Control and trying to program via the PLC IDE. I have had nothing but problems with uploading and connecting to the device using the IDE. I have been using the standard Arduino IDE to troubleshoot and debug my sketch and then copy it over the PLC IDE for testing with my ladder logic. The sketch runs fine when uploaded via the normal IDE, but when I install the PLC runtime and upload via the PLC IDE (which takes multiple attempts and I usually have to flash the bootloader and rerun the memory partitioning) it seems to fail to properly initiate the PLC ladder logic. I just get the message 'Failed accept(): 2!!' spamming out the serial port and the device seems to lock up. Then I have to go through the wifi_bootloader and memory_partioning to get it to connect to the PLC IDE again. Here is the output from the serial port monitor when the error occurs:
** Initializing FileSystem QSPI in 3...
** Initializing FileSystem QSPI in 2...
** Initializing FileSystem QSPI in 1...
Checking QSPIF partition scheme...
Wifi Data:
Partition type 11
Partition num 1
Partition size 1044480
Partition start 4096
Sending: Partition stop 1048576
Ota Data:
Partition type 11
Partition num 2
Partition size 5242880
Partition start 1048576
Partition stop 6291456
User Data:
Partition type 11
Partition num 3
Partition size 8388608
Partition start 6291456
Partition stop 14680064
QSPI partition scheme is correct, no need to whole reformat
Removing previous PLC code file...ERROR The file is not deleted (maybe it wasn't present ?).
QSPI Flash Storage Ready.
** PlcMain running
Network started with DHCP...
Network status 2
Initializing Partitions of file system...
Mounting LittleFS filesystem on Partition 3...
FileSystem correctly initialized
Stop PLC tasks
** Waiting for PLC tasks to finish ...
** All PLC tasks finished
Set PLC status to NOT OK
Reset PLC data area
Reset PLC data blocks
Set PLC entry points to NOP
Reset PLC application version information
** PLC FAST task created
** PLC SLOW task created
** PLC BACKGROUND task created
** All plc tasks created and ready
** Scheduler task created
** PLC FAST task period updated: 10000 us
** Waiting TCP/IP connections on port 502
!! Failed accept(): 2!! Failed accept(): 2** Starting to load PLC application
Notify the hosting environment of the beginning of PLC load process
!! Failed accept(): 2Reset currently executing PLC application ID
!! Failed accept(): 2Ensure a formally valid new PLC application has been loaded into PLC run-time code area
!! Failed accept(): 2!! No formally valid new PLC application found
!! Failed accept(): 2Stop PLC tasks
!! Failed accept(): 2** Waiting for PLC tasks to finish ...
!! Failed accept(): 2!! Failed accept(): 2** All PLC tasks finished
!! Failed accept(): 2Set PLC status to NOT OK
!! Failed accept(): 2Reset PLC data area
!! Failed accept(): 2Reset PLC data blocks
** PLC loading failed, error code 1
!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2** Hardware ID: bf426b08c6c0c736
!! AlPlcLoad failed
Device connected to AP
!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2Sending: !! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2CMD, KTS_0!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2
!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2Sending: !! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2CMD, KTS_0!! Failed accept(): 2!! Failed accept(): 2!! Failed accept(): 2
Has anyone else had this issue, or know what might be causing it? Any help is greatly appreciated.
